Why number is being rounded on eCart and why Dimensions not passed
Thread begun 6/12/2020 9:45 am by lr_leal239405 | Last modified 6/12/2020 10:11 am by Ray Borduin | 1651 views | 3 replies |
lr_leal239405
I have a question on an eCart function. I have an Add to Cart on a page where the code is passing the Price value as rounded. I get for example $84.00 instead of $84.15. The formula is below along with the entire AddToCart function. (the number comes from price being $99.00 - 15% which equals 84.15). on the cart.php the price comes in as $84.00. Also, on the confirm cart, it does not calculate shipping from this page(s) addToCart even though that record definitely has values in Length Width Height and Weight. (on any items from my main Shopping cart page, it does calculate shipping). I don't know what I'm missing. Any general info would help.
// WA eCart MySQLi AddToCart
if (isset($_POST["eCart1_1_ATC"]) || isset($_POST["eCart1_1_ATC_x"])) {
$ATC_itemID = $_POST["eCart1_1_ID_Add"];
$ATC_AddIfIn = 0;
$ATC_RedirectAfter = "../eCart/cart.php?quote=yes";
$ATC_RedirectIfIn = "";
if (function_exists("rel2abs")) {
$ATC_RedirectIfIn = $ATC_RedirectIfIn?rel2abs($ATC_RedirectIfIn,dirname(__FILE__)):"";
$ATC_RedirectAfter = $ATC_RedirectAfter?rel2abs($ATC_RedirectAfter,dirname(__FILE__)):"";
if ("Recordset2reccart" != "") $Recordset2reccart->FindRow("",$ATC_itemID);
$ATC_itemName = "".($Recordset2reccart->getColumnVal("part_name")) ."";// column binding
$ATC_itemDescription = "".($Recordset2reccart->getColumnVal("description")) ."";// column binding
$ATC_itemThumbnail = "". "" ."";// column binding
$ATC_itemWeight = floatval("".($Recordset2reccart->getColumnVal("Weight")) ."");// column binding
$ATC_itemQuantity = floatval("".($Recordset2reccart->getColumnVal("quantity")) ."");// column binding
//$ATC_itemQuantity = "".$_POST["eCart1_1_Quantity_Add"] ."";// column binding
//$ATC_itemQuantity = "". "1" ."";// column binding
$ATC_itemPrice = number_format(floatval(($Recordset2reccart->getColumnVal("price")) - ($Recordset2reccart->getColumnVal('discount') * 100)),2, '.', '');// column binding
$ATC_itemeCartCatID = floatval("".($Recordset2reccart->getColumnVal("part_name")) ."");// column binding
$ATC_itemLength = floatval("".($Recordset2reccart->getColumnVal("Length")) ."");// column binding
$ATC_itemWidth = floatval("".($Recordset2reccart->getColumnVal("Width")) ."");// column binding
$ATC_itemHeight = floatval("".($Recordset2reccart->getColumnVal("Height")) ."");// column binding
$ATC_itemItemNumber = "".($Recordset2reccart->getColumnVal("part_no")) ."";// column binding
//$ATC_itemInStockQty = floatval("".(Recordset2reccart->getColumnVal("In_Stock_Qty")) ."");// column binding
//$ATC_itemQuestions = "".($WRecordset2recs->getColumnVal("Include_Questions")) ."";// column binding
//$ATC_itemShippingType = "". "ship_collect" ."";// column binding
if ("WADAecart_products" != "") $Recordset2reccart->Index = 0;
$ATC_itemQuantity = floatval($ATC_itemQuantity);
if (is_numeric($ATC_itemQuantity) && $ATC_itemQuantity != 0) {
$eCart1->AddToCart($ATC_AddIfIn, $ATC_RedirectIfIn, $ATC_itemID, $ATC_itemName, $ATC_itemDescription, $ATC_itemThumbnail, $ATC_itemWeight, $ATC_itemQuantity, $ATC_itemPrice, $ATC_itemeCartCatID, $ATC_itemLength, $ATC_itemWidth, $ATC_itemHeight, $ATC_itemItemNumber);
if ($ATC_RedirectAfter != "" && $eCart1->redirStr == "") $eCart1->redirStr = $ATC_RedirectAfter;
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF'].($_SERVER['QUERY_STRING']?"?".htmlentities($_SERVER['QUERY_STRING']):"");
(I added the number_format thinking that would be it, but it's not doing it)
Thanks.
The number_format would cause this issue, and your math seems wrong. I think it would be more like:
$ATC_itemPrice = $Recordset2reccart->getColumnVal("price") - ($Recordset2reccart->getColumnVal('discount') * $Recordset2reccart->getColumnVal("price"));// column binding
lr_leal239405
Oops. yes. Thanks. Math was my worst subject (don't know how I ended up doing programming) :).
I had generic question above on why not calculating shipping when I'm passing Length Width Height and Weight (I think that's all it needs for UPS to calculate) but it works fine from my Shopping cart page. (I'm trying to fix it now. Maybe you'd have to see it all for you to determine).
I think UPS uses weight primarily. You only need to pass length, width, and height if it is an excessively large item for it's weight.
