detect system language
Thread begun 6/12/2020 3:52 am by Jonas | Last modified 12/01/2020 12:22 pm by Ray Borduin | 2179 views | 7 replies |
Jonas
How can I detect system language in a query?
I have found a site that very well describes how to build a multilingual website. The address is: https://www.apphp.com/tutorials/index.php?page=multilanguage-database-design-in-mysql
I intend to use method 4 for my project.
The article shows examples of what a sql query can look like to retrieve appropriate title according to the chosen language in the system.
I think this seems like a smooth solution. Or do you have any better suggestions?
According to another website, you can "pick" the browser language: https://www.geeksforgeeks.org/how-to-detect-browser-language-in-php/
I call the session "lang". And I want to set this to "substr ($ _ SERVER ['HTTP_ACCEPT_LANGUAGE'], 0, 2);"
I have two questions if I should use the examples from the above mentioned pages.
1. How do I write the same query with the WA MySQLi Recordset?
2. How do I create the session. Is this code correct:
<? Php
@session_start ();
if (! isset ($ _ SESSION ["long"])) {
$ _SESSION ["long"] = "substr ($ _ SERVER ['HTTP_ACCEPT_LANGUAGE'], 0, 2);";
Is there any complete guide you offer on how to do this? It should be of great public interest.
1) You can create any query you want with the recordset. The code should work the same as in any example you are following.
2) You have too many quotes. I think it should be:
@session_start();
if (! isset(
$_SESSION["lang"])) {
$_SESSION["lang"] = substr($_SERVER['HTTP_ACCEPT_LANGUAGE'], 02);
Jonas
Thanks Ray! This works fine on the site I am working on - which contains two languages. But I now realize that those who have languages other than the two I set to detect, get a 404 error message. Is it possible to write the code so that all other languages, automatically go to, for example, English.
Here is the code I have on the index.php page:
@session_start();
if(true) {
$_SESSION["lang"] = "".substr($_SERVER['HTTP_ACCEPT_LANGUAGE'], 0, 2) ."";
// Redirect browser
header("Location: http://localhost:8888/bucketlistNyServer/" . $_SESSION['lang'] . "/index.php");
exit;
@session_start();
if(true) {
if ($_SESSION["lang"] != "fr") $_SESSION["lang"] = "en";
// Redirect browser
exit;
Jonas
Okay, so I have to go through every language there is, if I understand correctly?
Any page that has that code. I'd put that code into an include file and then put it on every page, so if you ever need to add a language in the future you can do it from one file.
Jonas
No, what I mean was, I want to redirect those language that's not in the list to the en language. Is this possible without writing the code from every language?
I'm not sure what the second language you support is, but the line I added:
basically says "if it isn't french, use english"
You use that line to set it to english whenever it isn't set to the second language you support.
