WA_Email.php causing page to not load
Thread begun 6/09/2020 12:37 pm by eric284736 | Last modified 6/17/2020 1:31 pm by Ray Borduin | 1789 views | 5 replies |
eric284736
Hi Ray,
I have setup Sendmail to process the form on this page but on page load it freezes. When I disable the include call to <?php require_once("webassist/email/WA_Email.php"); ?> then the page will load. Not sure what is causing the problem.
Thanks,
Eric
eric284736
see pm
You had an old email version in your contactform.php include that conflicted with the new code. I updated the include to address the problem and the page loads now.
eric284736
Thanks Ray!
Which mail method is the most reliable? Mail , SMTP or Sendmail?
Thanks,
Eric
SMTP is the best I think since it uses the same format as your iphone or computer and prevents spam, but it is more strict and requires you to use an authenticated email address.
Mail is the easiest to get working and the most common when sending emails from a web page.
Sendmail is a wrapper that is similar to mail for UNIX and Linux based systems.
eric284736
Thanks Ray!!!
