Error in discount when buying more than one unit
Thread begun 6/09/2020 8:15 am by jspoerer286380 | Last modified 6/09/2020 10:46 am by Ray Borduin | 1059 views | 2 replies |
jspoerer286380
Hello... I have a discount rule defined in ecart that makes a 10% site wide from the total amount in the cart.... It works fine when one unit is added to the cart but when a quantity is raised in any item of the cart and ecart recalculates the new total... it doesn´t recalculate the discount... How can I make the discount consistent with the total in the cart even if you modify quantities of any item in it ??
Thanks,
Jorge from Chile
How did you create the discount? Can I see a screen grab of the discount rule you have set up? You probably just have to use TotalPrice instead of Price when calculating.
jspoerer286380
Thanks Ray.... you were right (as always)... I did the correction and now works perfectly!!
