I am having an issue using the MySqli server behavior on the login user.
Thread begun 6/09/2020 7:52 am by Jedi | Last modified 6/09/2020 4:11 pm by Ray Borduin | 2763 views | 4 replies |
Jedi
I have used the wizard to set up the login page and redirect page but I keep getting the following errors:Warning: Cannot modify header information - headers already sent by (output started at /homepages/24/d812057846/htdocs/bestbuypatiofurniture.com/login.php:1) in /homepages/24/d812057846/htdocs/bestbuypatiofurniture.com/webassist/mysqli/authentication.php on line 451
Notice: Undefined property: WA_MySQLi_Auth::$Log in /homepages/24/d812057846/htdocs/bestbuypatiofurniture.com/webassist/mysqli/authentication.php on line 274
Warning: sizeof(): Parameter must be an array or an object that implements Countable in /homepages/24/d812057846/htdocs/bestbuypatiofurniture.com/webassist/mysqli/authentication.php on line 274
Warning: Cannot modify header information - headers already sent by (output started at /homepages/24/d812057846/htdocs/bestbuypatiofurniture.com/login.php:1) in /homepages/24/d812057846/htdocs/bestbuypatiofurniture.com/webassist/mysqli/authentication.php on line 445
Please provide FTP access and steps to reproduce this issue. I can't see the problem in the code, so I'll have to debug it directly to determine why you are having problems.
Jedi
please see sftp in private message
There was some sort of weird corruption in your login.php file. A hidden character of some sort on line 1.
I fixed the problem by:
1) creating a new file
2) copy and pasting the entire login.php page into a text document
3) copying the code from the text file to the new document
4) saving over the login page with the new document
5) uploading the login page
Technically this should have resulted in the exact same page since I didn't change anything, but it seems to have corrected the issue.
Jedi
Hi Ray,
Thanks, a few other errors popped up so I noticed that the authentication.php file was different than those of other sites that have no issue for some reason. I changed the file with a working one and no problem now.
Thanks for your help.
