Just purchase Data Assist and getting the below issues.
Thread begun 6/01/2020 10:45 am by rogersds267040 | Last modified 6/09/2020 10:18 pm by Ray Borduin | 3806 views | 26 replies |
rogersds267040
1: This comes when navigating from result page to Detail page
Notice: Undefined index: WADA_CardType_Insert in C:\xampp1\htdocs\cardgen\binman\binDetails.php on line 17
2: My charts don't load after the conversion. Please see the attachments before and after.
I'd need to see a copy of the binDetails.php page to debug that error. Please attach it to a reply.
I don't see any changed code on the charts pages other than the "after conversion" one missing the connection file at the top. If you add the connection file reference back it will probably continue to work as it did before.
rogersds267040
DataAssist issue
Please seethe attached binDetails.php. This happens in all my detail pages. Not sure if it's php version related.
Sorry Ray, please see the attached charts_before.php.
Update line 17 of binDetails.php from:
$cardProductRS->bindParam("i", "".($_SESSION['WADA_CardType_Insert']) ."", "-1"); //ParamSessioncardProductID
$cardProductRS->bindParam("i", "".(isset($_SESSION['WADA_CardType_Insert'])?$_SESSION['WADA_CardType_Insert']:"") ."", "-1"); //ParamSessioncardProductID
The charts page has a lot of hand code. It would have to be updated by hand. If you want I can help with that in a premier support ticket.
rogersds267040
Thank you Ray. That changed cleared the error message.
I will reach out for the Premier ticket.
rogersds267040
I have before and after code from mysql to mysqli which isn't working.
Is there something that wasn't converted properly with mysqli?
Before DataAssist (Mysql to Mysqli) conversion
if ((isset($_POST["MM_insert"])) && ($_POST["MM_insert"] == "set_teller_status_form")) {
//If updating and not a first record and lhe last status was Busy updated the End Date of the last record
if($TellerStatus->TotalRows>0){
//echo $TellerStatus->getColumnVal('ACTIVITY_ID')." ".$TellerStatus->getColumnVal('Status');
//exit();
if($TellerStatus->getColumnVal('Status')=="Busy"){
$updateSQL = sprintf("UPDATE telleractivity SET endDateTime=NOW() WHERE activityID=%s",
GetSQLValueString($TellerStatus->getColumnVal('activityID'), "int"));
mysql_select_db($database_cardNumDS, $cardNumDS);
$Result1 = mysql_query($updateSQL, $cardNumDS) or die(mysql_error());
if(($_POST['Status']=="Unavailable") || ($_POST['Status']=="Available")){
$_POST['serviceID']="";
$editFormAction = $_SERVER['PHP_SELF'];
if (isset($_SERVER['QUERY_STRING'])) {
$editFormAction .= "?" . htmlentities($_SERVER['QUERY_STRING']);
$insertSQL = sprintf("INSERT INTO telleractivity (userID, serviceID, Status, displayName, branchNum, userName) VALUES (%s, %s, %s, %s, %s, %s)",
GetSQLValueString($_SESSION['userID'], "int"),
GetSQLValueString($_POST['serviceID'], "text"),
GetSQLValueString($_POST['Status'], "text"),
GetSQLValueString($row_WAATKusers ['displayName'], "text"),
GetSQLValueString($WAATKusers->getColumnVal('branchNum'), "text"),
GetSQLValueString($WAATKusers->getColumnVal('userName'), "text"));
$Result1 = mysql_query($insertSQL, $cardNumDS) or die(mysql_error());
$insertGoTo = "console.php";
$insertGoTo .= (strpos($insertGoTo, '?')) ? "&" : "?";
$insertGoTo .= $_SERVER['QUERY_STRING'];
header(sprintf("Location: %s", $insertGoTo));
After DataAssist (Mysql to Mysqli) conversion
$InsertQuery = new WA_MySQLi_Query($cardNumDS);
$InsertQuery->Action = "insert";
$InsertQuery->Table = "telleractivity";
$InsertQuery->bindColumn("userID", "d", "".($_SESSION['userID']) ."", "WA_BLANK");
$InsertQuery->bindColumn("serviceID", "d", "".($_POST['serviceID']) ."", "WA_BLANK");
$InsertQuery->bindColumn("Status", "s", "".($_POST['Status']) ."", "WA_BLANK");
$InsertQuery->saveInSession("telleractivityID");
$InsertQuery->execute();
$InsertGoTo = "console.php";
if (function_exists("rel2abs")) $InsertGoTo = $InsertGoTo?rel2abs($InsertGoTo,dirname(__FILE__)):"";
$InsertQuery->redirect($InsertGoTo);
This code looks correct to me. Please attach the actual php page? What are the symptoms? Do you get an error or it just doesn't work properly?
rogersds267040
The update piece not working. It supposed to update the table when the Status changes.
Please see the original file with and the converted to mysqli.
You mean the insert into the telleractivity table is not taking place at all, but there are no errors and it redirects to the console.php page?
It looks like you didn't add an update server behavior to the mysqli version. It was hand coded on the mysql version, so you would have to add it to the mysqli version, it wouldn't convert automatically.
The equivalent to this code is missing from the mysqli version of the page entirely:
if($totalRows_TellerStatus>0){
//echo $row_TellerStatus['ACTIVITY_ID']." ".$row_TellerStatus['Status'];
//exit();
if($row_TellerStatus['Status']=="Busy"){
$updateSQL sprintf("UPDATE telleractivity SET endDateTime=NOW() WHERE activityID=%s",
GetSQLValueString($row_TellerStatus['activityID'], "int"));
mysql_select_db($database_cardNumDS$cardNumDS);
$Result1 mysql_query($updateSQL$cardNumDS) or die(mysql_error());
if((
rogersds267040
Thank you Ray.
I thought mysqli conversion would of taken care of it.
