ecart error totals cart item amounts match order amounts
Thread begun 5/28/2020 5:00 am by georgina_barrett_187762 | Last modified 6/01/2020 12:04 pm by Ray Borduin | 2109 views | 5 replies |
I have a shop working now (in test mode) I am trying to do the same shop but in a different language (Spanish) . The problem is after the checkout.php page it just goes to the checkout_failure.php page. After looking through the forum I added the code:<?php @session_start(); var_dump($_SESSION); ?> to the payment_failure page and get the following results.
I have tried to compare the files from the other (working) shop but I can't see any difference.
Can I get steps to reproduce? If you view source on that code then I could tell more. It is hard to read without the tags which aren't visible without viewing the source code. You should put it in the private area, since it includes your paypal credentials. I'm updating your original post to move the debug code to the private area for security.
Thank you, I have just realised the problem is if you pick a colour that is 1 € extra. That is when you get the payment error. It is actually the same on the UK shop.
You just have to pass the correct adjusted price to paypal so the totals add up.
On line 55 of confirm.php you have:
$WA_PP_ECO_Do_itemized[0][$nextIndex] = "Amount" . strval($cartIndex+1) . "";
$WA_PP_ECO_Do_itemized[1][$nextIndex] = "".$esEmailCart->DisplayInfo("Price") ."";
it needs to be:
$WA_PP_ECO_Do_itemized[1][$nextIndex] = "".($esEmailCart->DisplayInfo("Price")+$esEmailCart->DisplayInfo("colourPriceInc")) ."";
Same concept on the pp_confirm.php on line 98. You have:
it needs to be:
Perfect, thank you. The only issue I have left is that on the checkout.php page (on both the UK and Spanish sites) the navigation menu dropdowns no longer work.
There were some missing javascript files on the bottom of your checkout.php page. I've added them and the menu seems to work now.
<script src="../../webassist/progress_bar/jquery-blockui-formprocessing.js" type="text/javascript"></script>
