Does User Level Authentication require adding additional columns to my database?
Thread begun 5/26/2020 11:24 am by tmcbinc99963 | Last modified 5/26/2020 4:24 pm by Ray Borduin | 735 views | 1 replies |
tmcbinc99963
I've created a log in page using SecurityAssist, which I'd like to use to set up User Level Authentication for several pages on the site (in multiple directories).
In the wizard 'Session Values Tab' it references a 'userlevel database column'. Should this be added to my database and contain the 1,2,3 values referenced in the tutorial?
Yes. That is one way to do it. You can save the access group in the user's table and save it as a session variable. Then use that session variable to create access rules.
