Spending over X and getting Y product free
Thread begun 9/18/2009 2:11 am by Suggs | Last modified 9/24/2009 8:56 am by Jason Byrnes | 5201 views | 7 replies |
Suggs
Hi Folks,
Im trying to work out how to do the following and am not having much luck.
if a customer buys any product that subtotal => £1000,00 they get a free product.
The free product is also a sellable product that can be purchased on its own and is listed in the product database.
The free product will always be the same product and not vary.
The free product needs to be automatically added at basket when the subtotal hits £1000,00 or above and be marked as free product.
Any pointers will be great
Paul
This will need hand coding to accomplish.
Probably the best way to accomplish it will be to to add a notice to the cart page that orders over £1000 get the free item. then only add it to the cart after they click the Confirm order button on the confirm page.
in other words only add to the cart once they checkout out.
The reason for this is that it will be difficult to remove the item form the cart if they get up to £1000 then remove items to get the cart below £1000.
To do this, on the confirm page, add an add to cart server behavior, set the price of the item to 0 and the name to Free - <name of the Item>. Set the trigger to Button Confirm Order Pressed.
The add to cart code will be added to the page with the following if statement:
if (isset($_POST["Submit_order"]))  {
add to cart code>
You will need to add another if statement around that to check the cart subtotal:
<?php if($WA_Store_Cart->GetTaxableTotal() => "1000") { ?>
add to cart code>
so that the item will only be added if they place the order and the order is equal to or greater than £1000
Suggs
Hi Jason,
Thanks for this.
I followed these guides you have given and had to create a recordset on the confirm page as there wasnt one there already..is this correct?? Also, this item is now only going to be an exclusive web offer that wont be sold on the site so is there a way i can create it as a static record for the giveaway and not use a database?
I followed your code and had to swap=> to >= as it bombed out, however now its bombing out with the following error
Parse error: syntax error, unexpected '{' in /home/barkerde/public_html/protx-confirm.php on line 331
This line of code looks like this:
<?php if ($stonehouse->GetTaxableTotal() >= "1000" { ?>
Also, when adding the ecart add to cart behaviour, im right in adding the get Contents From Recordset arent I?
Heres the relevant code the server behaviour generated. It also didnt give me a Button Confirm Order option in the trigger but a trigger option of Button: WADbSearch1 pressed which is the name of the button for the search box in the top of the page.
There is an option for current page submit...?????
Heres the code generated, along with the additional code you said to include:
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
$theValue = ($theValue != "") ? "'" . doubleval($theValue) . "'" : "NULL";
break;
case "date":
break;
case "defined":
break;
return $theValue;
mysql_select_db($database_barkeran, $barkeran);
$query_Recordset1 = "SELECT * FROM productimport";
$Recordset1 = mysql_query($query_Recordset1, $barkeran) or die(mysql_error());
$row_Recordset1 = mysql_fetch_assoc($Recordset1);
$totalRows_Recordset1 = mysql_num_rows($Recordset1);
// WA eCart Get Info From RS
$Redirect_redirStr="";
do {
$stonehouse_itemID = floatval("0");
$stonehouse_itemName = "Free - Union Jack Cushion";
$stonehouse_itemDescription = "";
$stonehouse_itemWeight = floatval("0");
$stonehouse_itemQuantity = floatval("0");
$stonehouse_itemPrice = floatval("0");
$stonehouse_itemThumbnail = "";
$stonehouse_itemShippingStatus = "";
$stonehouse_itemColour = "";
$stonehouse_itemSKU = "";
$stonehouse->AddToCart(1, "", $stonehouse_itemID, $stonehouse_itemName, $stonehouse_itemDescription, $stonehouse_itemWeight, $stonehouse_itemQuantity, $stonehouse_itemPrice, $stonehouse_itemThumbnail, $stonehouse_itemShippingStatus, $stonehouse_itemColour, $stonehouse_itemSKU);
} while ($row_Recordset1 = mysql_fetch_assoc($Recordset1));
if ($Redirect_redirStr != "") {
$stonehouse->redirStr = $Redirect_redirStr;
mysql_data_seek($Recordset1, 0);
<?php } ?>
Paul
Since the Item is going to be the same all the time, you really dont need to use a recordset to look it up, you could just enter the information in the bindings panel. Actually using a recordset will just add unneeded overhead.
The error you are getting is because you are missing a closing parenthesis in the if statement:
should be:
<?php if ($stonehouse->GetTaxableTotal() >= "1000") { ?>
Suggs
Hi Jason,
Thanks for this.
Sorted the closing parenthesis.
When you say i can enter the information in the bindings panel, how is the best way to go about this?
Ive looked in the bindings panel of Dreamweaver and am not sure about how to apply what you have mentioned.
Any pointers to get this up and running will be greatly appreciated
I meant on the Bindings tab of the Add to Cart button.
In the add to cart button behavior, instead of using a recordset, you should enter the information for the item manually. There is no need to use a recordset for this if the item will never change.
Suggs
Hi Jason,
Would this not interfere with the general checkout process as the buy now button carries info over that is populated from the database. The site has over 3000 products that are database driven and the only item that is being set up as a static item is the free item we are giving away with purchases over £1000.
The static item is the item that I need to have populated in the confirm page or the cart page to show the customer they qualify for the free item, and from an admin point, i need to have this item recorded in the database when a qualifying order is received so we know to send it out and for it to appear on the customers email and our order screen...effectively as if it were another product the customer bought. but at a zero cost because their other items subtotal £1000 or more.
if this item has to be driven from the database as well instead of being static to make it work then thats no problem..id just need to know how to work it out.
It should not be recordset driven. Only static.
The suggestion i am making is to add an add to cart button to the conform page, and modify the trigger so that it is only added when the customer 1) Clicks the Confirm order button and 2) when the total of the cart is over 1000.
The item will be added before the transaction is processed with the gateway, and before the order information is stored in the database. Since the item is added to the cart before these things happen, it will become a part of the order receipt, and will be stored in the database.
