Dynamic download issue
Thread begun 5/21/2020 10:44 am by Jose | Last modified 5/21/2020 12:59 pm by Ray Borduin | 2841 views | 9 replies |
Jose
Hi there, I'm trying to create a dynamic download page but it doesn't work properly. I have test it many times and in my conclusion the download page work proper as static but when I bind the field from the Recordset its downloads an empty folder. I'm going to attach two example static works and dynamic not works.
If you write the filename to the page:
<?php echo($Product->getColumnVal("filename")); ?>
What is the value?
It must not be: "filename.zip"
Because that is the filename that works. I don't think the issue depends on if it is dynamic or not. It shouldn't matter as long as the correct file name is passed.
Jose
Well, filename is just an example it could be any name but if I do something like this (<?php echo($Product->getColumnVal("filename")); ?>) I get the name of the file. For example: "gift.zip" and it doesn't work, I mean it download but empty. But if I put the name "gift.zip" instead of this ( "".($Product->getColumnVal("filename")) ."") then it works.
Jose
I am uploading two file then I will leave those link so you can see the results.
This website has an example of the results you can know by clicking the button.
Here are the links
This works and will download or open the zip
http://www.azarosa.com/static.php
Do not work and will download an empty zip
http://www.azarosa.com/dynamic.php
There is no difference between a value from a database and a value that is typed in, so something must be different in the file name between the dynamic and hard coded version. If you give me FTP access then I could debug and find the difference.
Jose
I agree with you. I Also tied this method (<?php echo($Product->getColumnVal("filename",false)); ?>) but not work
Well, I'll put FTP in PM down here.
You didn't include the FTP username
Jose
here you are.
This issue is caused by the extra space you have at the end of your assets/functions.php file.
You have added that file to your connections file, so once you add a connection, it gets added as well.
The extra space is written to the page before the download and corrupts the download file. If you remove that space the download will function properly.
Jose
Thank you Ray. I appreciate it
