SecurityAssist pages still accessible without login, invalid username/password login
Thread begun 5/19/2020 8:38 am by tmcbinc99963 | Last modified 5/21/2020 11:58 am by Ray Borduin | 5026 views | 10 replies |
tmcbinc99963
Pages still accessible without SecurityAssist login, invalid username/password login
After creating three new SecurityAssist pages, and letting the wizard create a new Db table, I still get 'invalid username or password error'.
Also, the pages are still accessible without logging in.
Files are attached. Access in PM if needed.
Your password was only 3 characters, but there was server validation on the password field requiring at least 6 characters. I've updated the page to allow 3 character passwords and it works for logging in now.
To make the pages inaccessible before logging in, go to each page and apply the restrict access to page server behavior.
tmcbinc99963
I downloaded your revised file, and changed the redirect to a different page. Before uploading I confirmed the server behavior still had 6 entries. Login now says 'invalid username and password' again.
Where is the logout button?
There isn't a logout button. Just add a link to the logout button wherever you want it.
It looks like you didn't download my update. Your line 24 has:
$WAFV_Errors .= WAValidateEL((isset($_POST["Log_In_group_2_Password"])?$_POST["Log_In_group_2_Password"]:"") . "",6,500,true,3);
I had updated it to:
$WAFV_Errors .= WAValidateEL((isset($_POST["Log_In_group_2_Password"])?$_POST["Log_In_group_2_Password"]:"") . "",3,500,true,3);
tmcbinc99963
File has been updated, and I applied the WA access server behaviors, but all pages have gone blank - login, access pages, etc.
Usually a white page is a database issue but it looks like the connect include is there.
There were 3 session starts at the top of the login page, so I removed two, but didn't make a difference.
Added error reporting, but still just blank pages.
I added code to display the errors on the top of the page like:
ini_set("display_errors",1);
Now it shows the issue is that you haven't uploaded your template file.
tmcbinc99963
I uploaded the templates and the pages look correct, but still don't work as expected.
When I try to log in, the page doesn't give me the 'invalid username' alert, but I'm not logged in and redirected to the results.php page either.
Your login is working... you had the wrong access rule applied on the restricted page you redirect to after login. I applied the correct rule to that page and it seems to work properly now.
tmcbinc99963
The login redirects to the correct page now. However, every one of the search criteria is resulting in a '404 file not found error', though the records are in the Db. It was working fine previously. Error report message is Undefined variable: totalRows_WADASalesCollateral line 76
Also, applying a Framebuilder theme strips away the code in the head region when applied. I created the DW template with two editable regions: HeadRegion and BodyRegion. When the template is applied, I resolve both of those to the head and body areas. When applying the WA theme, it asks me again to resolve the HeadRegion. Whether I choose head or nowhere it deletes code from the head area (mainly the css).
