I want to insert data to a column based on url so that one insert page can enter dataspecified in url
Thread begun 5/13/2020 2:28 pm by jo271221 | Last modified 7/01/2020 4:29 pm by Ray Borduin | 1312 views | 4 replies |
jo271221
Users are creating various posts and I want to insert the post_type by including the various post_types in the url.
Example: Golf. Bowling, Swimming
This is on a mySQLi page
Existing code in PM
Use the post type from the url to populate a hidden form element and then use the hidden form element to insert it into the database.
jo271221
Thank you,
Would the url look like this mysite.com/add-record.php?post_type=Golf Event ?
Is the hidden field
<?php echo($WADAbettybracer->getColumnVal("post_type")); ?>
That is a reference to a recordset column. To populate a hidden field you would use:
<input type="hidden" name="post_type" value="<?php echo($_GET["post_type"); ?>">
jo271221
Thank you! That worked great and you can insert into multiple columns. Just make sure you have corresponding inserts at the top of the page, then the hidden get elements. The url is something like: mysite.com/addrecord.php?post_type=my Special Post&col2=col2data&col3=col3data
There is an ending bracket missing in the above get, it should be:
<input type="hidden" name="post_type" value="<?php echo($_GET["post_type"]); ?>">
