Why does it show 'this record has been removed' when trying to insert to Db
Thread begun 5/13/2020 12:40 pm by tmcbinc99963 | Last modified 5/14/2020 2:27 pm by Ray Borduin | 1683 views | 5 replies |
tmcbinc99963
I created several DataAssist pages, one being an insert page to add a new record. However, after clicking the insert button, the Details show this record has been removed. The Db table is set up with AI and allows null values. The other pages seem to work correctly.
Insert page attached.
Is the record inserted into the database and just not displayed, or is the insert failing?
tmcbinc99963
The insert is failing. There's no record added.
Probably a required database field isn't being set. If you give me FTP access and a url to test then I could try to figure it out.
tmcbinc99963
The files are online.
The 'results > Detail' and the 'Detail > update' flows don't work, but the Update button from the results page seems to work fine. See PM.
The insert was working. It looks like the recordset that was supposed to be placed on the update page was put on the insert page by accident when the wizard ran. I moved the code and the pages seem to be working now.
