Email not sending
Thread begun 5/12/2020 8:30 am by balexander389215 | Last modified 5/12/2020 12:29 pm by Ray Borduin | 1030 views | 3 replies |
balexander389215
Email not sending
I have created a simple contact form but cannot get it to work.I have tried using smtp port 465 then 587 and finally 25 in case this was the error but no luck. I did get an error about line 21 at one point but that hasn't reappeared.I have created many contact forms and not had these problems though that was with the previous version. Could you point me in the right direction please.
I added the code to display errors and received the following
Fatal error: Uncaught Error: Class 'WA_Email' not found in /home/awieseth/public_html/contacts.php:24 Stack trace: #0 {main} thrown in /home/awieseth/public_html/contacts.php on line 24
That line is this: $Email = new WA_Email("contacts");
I created this from the form and this is what it created so I don't know what is supposed to be on that line.
It looks like the include file was placed too low on the page. Try moving line 40 up to the top of the page, that should fix the error.
balexander389215
Thanks Ray, That has solved part of the problem in that it appears to send and redirects to the correct page. However nothing is being received at the other end. I specifically created an email account to use as the username and password for this and tested by setting it up in Thunderbird so I know the sending from this email does work. I have checked and double checked all the settings and tried using different ports but nothing is received at the other end.
It is probably an issue with the dollar sign in the password. Try adding a backslash before it like: \$
