How can I get email to redirect to confirmation page?
Thread begun 5/08/2020 5:25 am by jack343289 | Last modified 6/19/2020 7:06 am by Ray Borduin | 2336 views | 8 replies |
jack343289
I have changed Hosting and getting error. The email is not redirecting to confirmation page nor as I understand is the email being sent? It was working before I changed hosting companies. I now just get a blank page of the original page that contact form.
Thank you
You are using a really old version of databridge with a newer version of PHP. You may want to upgrade to DataBridge v2 so you don't run into issues like this.
For now I can send you an updated version of the file throwing the error you can replace to fix this problem.
jack343289
jack343289
Ray
Sorry that didn't work tried it on another site as well
Regards
Jack
I went to the contact form and it seems to work. How would I reproduce the error?
jack343289
Most likely it is failing the server validation. If you remove that does it send the email?
jack343289
Ray
I have removed the server validation, but no email, no redirect. So I have changed the PHP Version on the webhosting from &.7.3 to 5.6. It now works.
Thank you
Data Bridge 2.0 is fully updated to work with php7. It has an improved email implementation and MySQLi support.
