How to set cookie for remembering data-toggle status for next page
Thread begun 5/08/2020 1:11 am by Rokon | Last modified 5/08/2020 10:54 am by Ray Borduin | 1427 views | 3 replies |
Rokon
Hello
Could you pls help me to set a cookie value in order to remember the button data toggle status on every page. Example I have a page where I have set of button for toggle the show hide some portion of the page base on the button toggle status. I need to remember the button toggle status when user go to next page through the page navigator.
The code is like as below;
Button toggle code
<div class="btn-group float-right btn-block" role="group" aria-label="Control Button set for show/hide">
<button id="showHideArabic" data-toggle="button" aria-pressed="true" type="button" class="btn btn-md btn-outline-dark active"><i class="fas fa-comment-dots"></i></i> আরবী</button>
</div>
Buttons show/hide function run via the jquery as below in head;
<script>
// For show / hide button
$(document).ready(function(){
$("#showHideArabic").click(function(){
$("div.showArabic").fadeToggle(1000);
</script>
We have a Set Cookie Value server behavior you can use to set a cookie. You could apply that onclick of the button.
Rokon
little bit demo base on the script i putted over would be help me out. Thanks.
I don't have a tutorial. Use the behaviors window to set the cookie on click and then display it on the next page.
Once you have it set and displaying then you can start working on getting it to control the default toggle status.
