DataAssist
Thread begun 5/07/2020 1:30 am by Paul | Last modified 5/07/2020 3:35 pm by Ray Borduin | 2211 views | 3 replies |
PaulBeta Tester
DataAssist
Can the wizard offer a non css formatted option in the next release?
Which CSS is causing issues? Some designs have only the most basic CSS added and that should be easy enough to remove or replace.
PaulBeta Tester
arguably its simple enough to remove, however the process of removing does add to development time and there is an increase in risk of inavertantly removing an element which is linked to the fuctionality.
Thanks for the suggestion. I'll certainly consider a simpler option that maybe just places the form elements on the page that you can move around and style as the developer.
