Search/Results aren't working using Search Wizard and DataAssist results pages
Thread begun 5/05/2020 12:52 pm by tmcbinc99963 | Last modified 5/06/2020 5:00 pm by Ray Borduin | 1892 views | 5 replies |
tmcbinc99963
Because the DataAssist 'pages' don't create radio or checkbox Search form elements, I used the Search Wizard to reconfigure an existing radio/checkbox form, and then created a results page using the DataAssist pages.
However, I can't get the Search page and Results page to work together.
In addition, the related recordsets created are lost every time the DataAssist Search server behavior is opened and edited.
Tried starting from scratch and having the Search Wizard create new from existing Db table along with a new results page. This doesn't work either, only returning all records.
I'd also like to add the search form to the top of the results page (the one created with the results page only has text fields). What is the best way to accomplish this?
Files are included.
Radio buttons and checkboxes work by submitting the value attribute. It looks like you have the values set to value="radio" and value="checkbox" instead of having the value set to what you want to be found in the database. I think if you just update the values it will work correctly.
You can always copy and paste the form onto the results page, or use the Framework->Insert Plugin server behavior to add it to the page that way.
tmcbinc99963
The Search Wizard search form was pasted into the Results page. Never got the pasted search form to submit any results, so I'm trying to convert the text fields from the existing Results page search into radio buttons and checkboxes.
I've partially succeeded, but the results have been mixed. The searches return unexpected results, even from the text fields, and some don't work at all, though they worked previously.
It seems as though the problem is in the way the queries are filtered in the Search Wizard. I've tried using different combinations in the Wizard, but none work consistently.
Also, how is a unique value added to each entry in a dynamic select list?
The page is attached. I can post live if that's easier to troubleshoot.
You have a couple of recordsets that seem to be repeated an unused.
I think you can update line 477 from $row_RsSalesCollateral['Headline'] to $row_WADASalesCollateral['Headline'].
Then you can delete lines 174-192.
That isn't the source of your problem, just clean up.
Next add this to the body of the page:
<?php echo($query_WADASalesCollateral); ?>
That will show you the resulting query with the filter and allow you to see why it isn't working.
tmcbinc99963
I entered the code, but every search ends with: SELECT ID, Type, Category, Headline, MediaDesc, MediaName, Media, link FROM SalesCollateral WHERE (Type = '
I've deleted everything but the search form that's needed to make it simpler. But, I obviously don't understand how to set up the DataAssist Search recordset to search the relevant elements.
Rather than the dynamic radio button list I wanted, I've set it up where each radio button is independent (same with checkboxes). I've tried using select and check in the wizard, along with a php value and also an entered value. The entered value was the only one that would ever work, but don't see how the other records can be found using only one value. The checkboxes have the same issue. Does this require multiple recordsets or can I get the search results using the one DataAssist Search recordset?
Also trying to set up a keyword text field that will find everything but also works in conjunction with the buttons above it. This returns no results.
Now it's as if the form isn't even submitting, though the progress bar shows up briefly.
New page is attached.
It looks like you bound the filter to the recordset columns instead of entering the form element names. lines 16-21 should be something like:
$WADbSearch1->addComparisonFromList("Type","TypeFormElementName","AND","Includes",0);
$WADbSearch1->addComparisonFromEdit("Category","CategoryFormElementName","AND","=",0);
$WADbSearch1->addComparisonFromEdit("Headline","HeadlineFormElementName","AND","Includes",0);
$WADbSearch1->addComparisonFromEdit("MediaDesc","MediaDesc","AND","Includes",0);
$WADbSearch1->addComparisonFromEdit("MediaName","MediaName","AND","Includes",0);
$WADbSearch1->SalesCornerRadioGroup("Media","SalesCornerRadioGroup","AND","=",0);
With the actual form element names used from the search form.
