encryption
Thread begun 5/05/2020 4:45 am by Sweens | Last modified 5/06/2020 11:34 am by Ray Borduin | 2747 views | 8 replies |
Sweens
encryption
Hi Ray
I have been using crypt encryption on most sites, but notice it is no longer available (ssee screenshot).
Which form of encryption is the most secure - I'm using php 7.4
Many thanks
Chris
It really depends on what you are encrypting and if you need to decrypt or search the field you are encrypting.
Sweens
Thanks Ray
It's only for the password field.
Is one of the options compatible with crypt, so existing users don't need to change passwords (though that isn't a major problem).
Cheers
Chris
Crypt actually should still be available. It is still supported in php7. I'll look into why it isn't showing in the bindings. You could just add the include file and reference the crypt function manually for now.
Sweens
Thanks - I'd wondered if I could do that.
Cheers
Chris
Here is a new formats.xml file that will add that option back. Just replace your version in your user's configuration folder: Configuration/ServerFormats/PHP_MySQL/Formats.xml
Sweens
Thanks Ray
Unfortunately, that hasn't made a difference; I have rebooted the computer, just in case, but no change. Looking at the old Formats.xml page, there were no encryption lines
Cheers
Chris
This should be in your USERS configuration... not the program files directory.
Sweens
Thanks Ray - all OK now.
Cheers
Chris
