Search form not returning matched long integers
Thread begun 5/04/2020 6:37 pm by Paul | Last modified 5/07/2020 9:41 am by Ray Borduin | 1075 views | 3 replies |
PaulBeta Tester
One of my search form criterior is mobile number.
Values are stored in my sql table as bigint set to 15 char length.
The search form contains the following
$searchWADAsimdb_1->setSearch(array("type"=>"Edit", "comparison"=>"=", "join"=>"AND"), array("simNum"), "d", "simNum");
yet if i type the exact 10 digit number in my search form, its not matched to the same value stored.
Can large int numbers be searched safely or does the sql handle them differently?
It should work. Try doing a text search instead of a numeric search by changing the "d" to a "s".
PaulBeta Tester
Thanks.
Ensuring the insert and update pages, as well updating the sql table all to reflect ‘text’ for these fields was successful.
It seems counter intuitive to change a data field storing an integer to a text field though.
I agree. What is the data type in the database? I would think they would work the same.
