Adding a filter to a repeating table
Thread begun 5/01/2020 5:11 pm by Paul | Last modified 5/04/2020 9:41 am by Ray Borduin | 533 views | 1 replies |
PaulBeta Tester
I would like to filter a generated repeating table, using a selectable phrase (present) in the results returned in the table.
Are there any tools in the WA DB suite?
The results are created on the fly when a page loads - no search page.
im thinking maybe have a drop down in a search form at the top of the page to build a search result. Possibly linked to a recordset which runs dynamically when a user selects a filter - sounds like quite a weighty option though.
May 4th Follow up.
Other options, if anyone interested are here
https://www.w3schools.com/php/php_ajax_database.asp
https://www.w3schools.com/howto/howto_js_filter_table.asp
https://www.w3schools.com/jquery/jquery_filters.asp
I think your solution sounds correct. The webassist Database Search server behavior should be helpful if you are doing anything complex in your search. If it is just a single phrase search across a single column, then a simple recordset parameter would probably do the trick.
