I want to insert a url to an image file name being inserted to the database with a simple file browse
Thread begun 4/29/2020 6:45 pm by jo271221 | Last modified 5/06/2020 5:02 pm by Ray Borduin | 2832 views | 9 replies |
jo271221
I want to insert the full path to the image so that the image can be viewed on various pages and websites within our network without the need of having the path the the image on the page.
We are doing this on another site using the html editor. file kfm/configuration
$kfm_userfiles_output = "https://mywebsite.com" .rel2abs($kfm_userfiles_address,dirname(__FILE__));
On this site we are not using the html editor or file manager and I don't have a kfm directory
On line 23 of wa/file-manipulation/helperphp.php I found this
function makeFolder($thePath) {
$thePath = str_replace("\\","/",$thePath);
$theParentPath = substr($thePath,0,strrpos($thePath,"/"));
Or possibly the kcfinder/conf/config.php
FTP info in PM
Just add it in the front when you display the image. I don't think you need it in the database.
If you want it in the database, just add it in front in the Insert to Database server behavior bindings.
jo271221
I need it to be inserted in the DB -
original
$UpdateQuery->bindColumn("horse_pic5", "s", "".($WA_DFP_UploadStatus["WA_UploadResult5"]["serverFileName"]) ."", "WA_BLANK");
Revision below worked other than I need the correct format to add the horse id -
<?php echo($WADAhorses_update->getColumnVal("horseid")); ?>
$UpdateQuery->bindColumn("horse_profile_pic", "s", "https://mysupersite.com/horse-sale-2020/horseid/".$WA_DFP_Status["WA_UploadResult2"]["WA_UploadResult2_1"]["serverFileName"] ."", "WA_BLANK");
My attempt at horseid did not work.
$UpdateQuery->bindColumn("horse_profile_pic", "s", "https://mysupersite.com/horse-sale-2020/$WADAhorses_update->getColumnVal("horseid")/".$WA_DFP_Status["WA_UploadResult2"]["WA_UploadResult2_1"]["serverFileName"] ."", "WA_BLANK");
It should be:
$UpdateQuery->bindColumn("horse_pic5", "s", "https://mysupersite.com/horse-sale-2020/".$WADAhorses_update->getColumnVal("horseid") ."/".($WA_DFP_UploadStatus["WA_UploadResult5"]["serverFileName"]) ."", "WA_BLANK");
Just make sure the WADAhorses recordset code is above this code.
jo271221
Thank you!!! That worked perfectly!
jo271221
OOPS - It did not work perfectly. The url prefix s getting inserted whenever the page is updated NOT just when the user adds pictures.
If you add a new image it works. But if you update the page without adding a new image it does not work.
Please see PM.
Try this... first remove all of the default file names in the file uploads, so the lines:
'DefaultFileName' => "".($WADAhorses_update->getColumnVal("horse_profile_pic") ) ."",
become:
'DefaultFileName' => "",
Then update the bindings from:
$UpdateQuery->bindColumn("horse_profile_pic", "s", "https://mysupersite.com/horse-sale-2020/".$WADAhorses_update->getColumnVal("horseid") ."/".($WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"])  ."", "WA_BLANK");
  $UpdateQuery->bindColumn("horse_pic2", "s", "https://mysupersite.com/horse-sale-2020/".$WADAhorses_update->getColumnVal("horseid") ."/".($WA_DFP_UploadStatus["WA_UploadResult2"]["serverFileName"])  ."", "WA_BLANK");
  $UpdateQuery->bindColumn("horse_pic3", "s", "https://mysupersite.com/horse-sale-2020/".$WADAhorses_update->getColumnVal("horseid") ."/".($WA_DFP_UploadStatus["WA_UploadResult3"]["serverFileName"])  ."", "WA_BLANK");
  $UpdateQuery->bindColumn("horse_pic4", "s", "https://mysupersite.com/horse-sale-2020/".$WADAhorses_update->getColumnVal("horseid") ."/".($WA_DFP_UploadStatus["WA_UploadResult4"]["serverFileName"])  ."", "WA_BLANK");
$UpdateQuery->bindColumn("horse_profile_pic", "s", "".($WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"]?"https://mysupersite.com/horse-sale-2020/".$WADAhorses_update->getColumnVal("horseid") ."/".($WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"]):"")  ."", "WA_IGNORE");
  $UpdateQuery->bindColumn("horse_pic2", "s", "".($WA_DFP_UploadStatus["WA_UploadResult2"]["serverFileName"]?"https://mysupersite.com/horse-sale-2020/".$WADAhorses_update->getColumnVal("horseid") ."/".($WA_DFP_UploadStatus["WA_UploadResult2"]["serverFileName"]):"")  ."", "WA_IGNORE");
  $UpdateQuery->bindColumn("horse_pic3", "s", "".($WA_DFP_UploadStatus["WA_UploadResult3"]["serverFileName"]?"https://mysupersite.com/horse-sale-2020/".$WADAhorses_update->getColumnVal("horseid") ."/".($WA_DFP_UploadStatus["WA_UploadResult3"]["serverFileName"]):"")  ."", "WA_IGNORE");
  $UpdateQuery->bindColumn("horse_pic4", "s", "".($WA_DFP_UploadStatus["WA_UploadResult4"]["serverFileName"]?"https://mysupersite.com/horse-sale-2020/".$WADAhorses_update->getColumnVal("horseid") ."/".($WA_DFP_UploadStatus["WA_UploadResult4"]["serverFileName"]):"")  ."", "WA_IGNORE");
  $UpdateQuery->bindColumn("horse_pic5", "s", "".($WA_DFP_UploadStatus["WA_UploadResult5"]["serverFileName"]?"https://mysupersite.com/horse-sale-2020/".$WADAhorses_update->getColumnVal("horseid") ."/".($WA_DFP_UploadStatus["WA_UploadResult5"]["serverFileName"]):"")  ."", "WA_IGNORE");
jo271221
I am getting a blank page.
I've updated the code chunk above. It should have been:
jo271221
Perfect! Thank you!
