relational table and insert
Thread begun 4/27/2020 5:38 am by Jamie | Last modified 4/28/2020 10:38 am by Ray Borduin | 1099 views | 3 replies |
Jamie
Hey Ray
How would I get the attached insert page to add the relational info on insert?
Cheers
Jamie
Move the relational table code below the insert code.
Also, you can use a multiple insert server behavior rather than the Relational Table server behavior when working with insert page. That should decrease the complexity.
Jamie
thanks Ray
Am unsure what the bindings should be using the multiple insert as you suggest http://prntscr.com/s74im0
Have attached the page if it helps
Cheers
Call me and I'll help. I don't exactly understand what you are doing, so I'm having trouble giving more specific advice.
