Does webassist have code generator for echeck?
Thread begun 4/24/2020 2:49 pm by lr_leal239405 | Last modified 8/27/2020 11:58 am by Ray Borduin | 3710 views | 9 replies |
lr_leal239405
My boss wants me to implement a way for people to pay with checks (or direct banking) online. We already have a working eCart (as you helped a lot with). But now they want to eCheck wihich it's called using Authorize.net (that's what we're using). I'm looking for the easy way out (as many of us are ;) ). If not, I'll keep looking on how to implement through their API and online info. Thanks.
I think our code could be updated to work with eCheck. I believe just a few fields would be updated, but it would probably have to be done by hand. This is something I could help with in a premier support ticket.
lr_leal239405
How long do you think it would take?
Probably around 2 hours assuming you had all of the forms set up.
lr_leal239405
ok. well, let me set up forms first and see how far I get. I will probably need about that much time of tech support for other stuff i've been putting together that have some glitches to get through. thanks.
lr_leal239405
Sorry to bother you. Can you refresh my memory on where the handful of things to change are to get our existing Authorize.net account to work with eCheck?
see below: thanks.
x_method has to be changed to "ECHECK"
Then you can get rid of:
x_card_num
x_exp_date
x_card_code
Then you have to set:
x_bank_aba_code = Routing number of a bank for eCheck.Net transactions.
x_bank_acct_num = Checking or savings account number.
x_bank_acct_type" = Acceptable values include CHECKING, BUSINESSCHECKING, and SAVINGS.
x_bank_name = Contains the name of the customer's financial institution.
x_bank_acct_name = The cutomer's name as it appears on their bank account.
x_echeck_type = Indicates the type of eCheck.Net payment request. Acceptable values include CCD, PPD, TEL, and WEB.
lr_leal239405
This is what I got, but it's not communicating with Authorize.net with this code. Does the below seem right?
<?php include("../template/session_track.php"); ?>
<?php require_once('../webassist/ecart/checkout/credentials/gateways.php'); ?>
<?php require_once('../Connections/convacc_cx.php'); ?>
<?php require_once('../webassist/mysqli/rsobj.php'); ?>
<?php require_once("../webassist/forms/persist.php"); ?>
<?php require_once("../WA_eCart/Adv_CO_Scripts/AuthNet_PHP.php"); ?>
<?php session_start(); ?>
if (isset($_POST["CheckingAcct_submit"]) || isset($_POST["CheckingAcct_submit_x"])) {
$AuthNet_required = array();
$AuthNet_required[0] = array();
$AuthNet_required[1] = array();
$AuthNet_itemized = array();
$AuthNet_itemized[0] = array();
$AuthNet_itemized[1] = array();
$AuthNet_optional = array();
$AuthNet_optional[0] = array();
$AuthNet_optional[1] = array();
$cartIndex = 0;
$nextIndex = 0;
$nextIndex = count($AuthNet_required[0]);
$AuthNet_required[0][$nextIndex] = "x_login";
$AuthNet_required[1][$nextIndex] = "".($WA_Authorize_Net_API_Credentials_Login_ID) ."";
$AuthNet_required[0][$nextIndex] = "x_tran_key";
$AuthNet_required[1][$nextIndex] = "".($WA_Authorize_Net_API_Credentials_Transaction_Key) ."";
$AuthNet_required[0][$nextIndex] = "x_version";
$AuthNet_required[1][$nextIndex] = "3.1";
$AuthNet_required[0][$nextIndex] = "x_invoice_num";
$AuthNet_required[1][$nextIndex] = "".session_id() ."";
$AuthNet_required[0][$nextIndex] = "x_test_request";
$AuthNet_required[1][$nextIndex] = "".($WA_Authorize_Net_API_Credentials_TestMode) ."";
$AuthNet_required[0][$nextIndex] = "x_method";
$AuthNet_required[1][$nextIndex] = "ECHECK";
$AuthNet_required[0][$nextIndex] = "x_type";
$AuthNet_required[1][$nextIndex] = "AUTH_CAPTURE";
$AuthNet_required[0][$nextIndex] = "x_relay_response";
$AuthNet_required[1][$nextIndex] = "FALSE";
$AuthNet_required[0][$nextIndex] = "x_delim_data";
$AuthNet_required[1][$nextIndex] = "TRUE";
$AuthNet_required[0][$nextIndex] = "x_delim_char";
$AuthNet_required[1][$nextIndex] = "::";
$AuthNet_required[0][$nextIndex] = "x_customer_ip";
$AuthNet_required[1][$nextIndex] = "".$_SERVER["REMOTE_ADDR"] ."";
$AuthNet_itemized[0][0] = "x_amount";
$AuthNet_itemized[1][0] = "". ".01" ."";
$AuthNet_itemized[0][1] = "x_description";
$AuthNet_itemized[1][1] = "". $_POST["echeckmemo"] ."";
$AuthNet_optional[0][$nextIndex] = "x_bank_acct_name";
$AuthNet_optional[1][$nextIndex] = "".(WA_getSavedFormValue('WA_Payments','nameOnAcct')) ."";
$nextIndex = count($AuthNet_optional[0]);
$AuthNet_optional[0][$nextIndex] = "x_bank_aba_code";
$AuthNet_optional[1][$nextIndex] = "".(WA_getSavedFormValue('WA_Payments','addBankAccountRoutingNumber')) ."";
$AuthNet_optional[0][$nextIndex] = "x_bank_acct_num";
$AuthNet_optional[1][$nextIndex] = "".(WA_getSavedFormValue('WA_Payments','addBankAccountNumber')) ."";
$AuthNet_optional[0][$nextIndex] = "x_bank_acct_type";
$AuthNet_optional[1][$nextIndex] = "".(WA_getSavedFormValue('WA_Payments','addBankAccountType')) ."";
$AuthNet_optional[0][$nextIndex] = "x_bank_name";
$AuthNet_optional[1][$nextIndex] = "".(WA_getSavedFormValue('WA_Payments','addBankName')) ."";
$AuthNet_optional[0][$nextIndex] = "x_echeck_type";
$AuthNet_optional[1][$nextIndex] = "".(WA_getSavedFormValue('WA_Payments','addeCheckType')) ."";
$WAGatewayResponse = AuthNet_Post($AuthNet_required,$AuthNet_itemized,$AuthNet_optional);
if ($WAGatewayResponse) {
//$eCart1->redirStr = "checkout_success.php";
echo "SUCCESS";
} else {
echo "FAILURE";
exit();
So you see the failure message?
I'm sure you can get rid of:
But other than that it does look correct to me. Next I would check the session to see if you get an intelligent error message that might help you track down the problem. If you want to do a premier support ticket I could help you debug this.
try:
var_dump($WAGatewayResponse);
before the echo to see what is in the response that might be helpful to track down what is wrong.
lr_leal239405
The response was:
bool(false) FAILURE
I'll try calling you.
