Trying to add shipping exemption for digital item
Thread begun 4/20/2020 3:55 pm by Roxana | Last modified 4/23/2020 1:14 pm by Ray Borduin | 3093 views | 9 replies |
Roxana
I used the thread below to try to set up a shipping exemption for a digital item. Unfortunately I couldn't get it to work. It might be, because the Cart object is custom made (different currencies, shipping rules depending on location.
I created a column shippable in the database, with the digital item set to 0, all other items set to 1.
Could you please help?
http://www.webassist.com/forums/posts.php?t=15737
You would set the value of itemShippable in your add to cart server behavior for all add to cart buttons on your site.
Then just update the shipping rule requirements to require that the total of itemShippable is > 0 for all of your shipping rules.
Roxana
Luckily I only have one add to cart button on the detail page. But I have no idea how to set the value. Trying to set the value, it won't let me hit OK. So I couldn't test it.
Please attach a copy of the page and I'll take a look.
Roxana
Thanks. Here is the copy.
Please attach your cart object as well. I need that to open the interface.
I think you should be able to click OK. Try updating the code to:
// WA eCart MySQLi AddToCart
if (isset($_POST["segufix_1_ATC"]) && ($rspricelookup->getColumnVal('price') != "0") || isset($_POST["segufix_1_ATC_x"]))     {
$ATC_itemID = $_POST["segufix_1_ID_Add"];
$ATC_AddIfIn = 0;
$ATC_RedirectAfter = "/cart.php";
$ATC_RedirectIfIn  = "";
  if (
function_exists("rel2abs")) {
$ATC_RedirectIfIn = $ATC_RedirectIfIn?rel2abs($ATC_RedirectIfIn,dirname(__FILE__)):"";
$ATC_RedirectAfter = $ATC_RedirectAfter?rel2abs($ATC_RedirectAfter,dirname(__FILE__)):"";
  if (
"DetailRS1" != "") $DetailRS1->FindRow("product_id",$ATC_itemID);
$ATC_itemName = "".$DetailRS1->getColumnVal('name', false)  ."";// column binding
$ATC_itemDescription = "".$_POST['lookupname2']  ."";// column binding
$ATC_itemWeight = "".floatval("0")  ."";// column binding
$ATC_itemQuantity = "".$_POST["segufix_1_Quantity_Add"]  ."";// column binding
$ATC_itemPrice = "".($_SESSION['mylocation'] == 'canada')?floatval($rspricelookup->getColumnVal('price_can')):floatval($rspricelookup->getColumnVal('price'))  ."";// column binding
$ATC_itemarticle = "".$rspricelookup->getColumnVal('item_no_long')  ."";// column binding
$ATC_itemVersion = "".$rspricelookup->getColumnVal('version')  ."";// column binding
$ATC_itemSize = "".$rspricelookup->getColumnVal('size')  ."";// column binding
$ATC_itemLock = "".$rspricelookup->getColumnVal('lock_description')  ."";// column binding
if ("DetailRS1" != "") $DetailRS1->Index = 0;
$ATC_itemQuantity = floatval($ATC_itemQuantity);
  if (
is_numeric($ATC_itemQuantity) && $ATC_itemQuantity != 0)     {
$segufix->AddToCart($ATC_AddIfIn, $ATC_RedirectIfIn, $ATC_itemID, $ATC_itemName, $ATC_itemDescription, $ATC_itemWeight, $ATC_itemQuantity, $ATC_itemPrice, $ATC_itemarticle, $ATC_itemVersion, $ATC_itemSize, $ATC_itemLock);
    if (
$ATC_RedirectAfter != "" && $segufix->redirStr == "") $segufix->redirStr = $ATC_RedirectAfter;
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF'].($_SERVER['QUERY_STRING']?"?".htmlentities($_SERVER['QUERY_STRING']):"");
If you still have issues, then please attach the cart object and I can try. You should be able to click the OK button.... maybe try reinstalling the extension.
Roxana
This happened. When I click OK, it just closes the window.
You have your add to cart button set to be hidden.
<input class="inputClass"
then inputClass has display:none;
That causes an issue since it tries to select the button on the page when updating. I think if you just remove the class from the input button then you can access the server behavior. Then add the class back after you are done.
Roxana
I deleted the input class. But still get the same error message.
Try closing and opening the page after removing the class before accessing the server behavior. Please attach the current version of the page so I can try to reproduce the issue if it still happens.
