Main is not going and showing Fatal error
Thread begun 4/20/2020 12:06 pm by Rokon | Last modified 4/21/2020 4:39 pm by Ray Borduin | 2720 views | 9 replies |
Rokon
Mail is not going and showing Fatal error
Hello
I am having a problem with email delivery, I have been trying from yesterday but without any result.
I am getting the error as below;
Fatal error: Uncaught Error: Call to a member function Prepare() on null in /home1/x0g1kgnj/new.hadithbd.com/webassist/mysqli/rsobj.php:203 Stack trace: #0 /home1/x0g1kgnj/new.hadithbd.com/hadith/email/hadith-email.php(7): WA_MySQLi_RS->execute() #1 /home1/x0g1kgnj/new.hadithbd.com/webassist/email/WA_Email.php(314): require('/home1/x0g1kgnj...') #2 /home1/x0g1kgnj/new.hadithbd.com/webassist/email/WA_Email.php(473): WA_Email->getFromPage('hadith-email.ph...') #3 /home1/x0g1kgnj/new.hadithbd.com/hadith/email/index.php(62): WA_Email->send(0) #4 {main} thrown in /home1/x0g1kgnj/new.hadithbd.com/webassist/mysqli/rsobj.php on line 203
Below is may page link to try: http://new.hadithbd.com/hadith/email/?id=102
When you add a recordset to an email body you have to use require() instead of require_once() for adding the connection. So this on hadith-email.php:
<?php require_once('../../Connections/hadithbd.php'); ?>
should be this:
<?php require('../../Connections/hadithbd.php'); ?>
Or you could just carry it over as a global variable like:
global $hadithbd;
Rokon
should be this:
global $hadithbd;
I change the connection to <?php require('../../Connections/hadithbd.php'); ?> and uploaded the file newly, now no error is showing but mail also not going too, it is neither shows a success message nor anything just browser shows it is loading for infinity
I added this line to the email code:
$Email->SMTPDebug = 3;
That displays the SMTP communication between the web page and email server. It appears your smtp server information is not correct.
Rokon
Well at last it works! the SMTP port was creating trouble. Thanks for your great support Ray.
Rokon
For the first and last time just one email came and after that every time it shows success message but email never appear in anywhere, checked spam etc but nothing. Pls help.
I turned on email debug again and saw your smtp server was giving an encryption error. So I turned off your email encryption settings and that seems to have fixed it.
Now the email sends, but I get an error because you have email logging turned on and set to insert into the email_log table in your database, but that table doesn't exist. You can either delete lines 55-62 to remove the logging, or create the table in the database so it can insert properly.
Rokon
Well at last is working! I added the table manually and now inserting the data and without any error!
Thanks again.
Rokon
Email is delivering but the security captcha has no effect
I noticed that the security captcha is not working nor even showing any error! Whatever i put as security text it just accept everything. Can you pls have a look what I am doing wrong?
You only have required validation set for the CAPTCHA, not Like Entry validation, which is required to check they are both the same.
I've gone ahead and added the server validation for you.
