No database access since DW update
Thread begun 4/20/2020 11:02 am by Sweens | Last modified 4/22/2020 12:31 pm by Ray Borduin | 1597 views | 5 replies |
Sweens
Hi Ray
Since the latest Dreamweaver update a couple of days ago, I can't connect locally to my database - I get the following error:
Your PHP server doesn't have the MySQL module loaded or you can't use the mysql_(p)connect functions
I'm still able to access the same pages OK using DW 2016 (and recent XAMPP from June 5th 2019) andI'm using MySQL_i
Is there a setting on the configuration I need to change?
Many thanks
Chris
Try reinstalling DataBridge. It could have overwritten your database connection files with the Adobe version that doesn't support mysqli.
Sweens
Hi Ray
Thanks - I've done that, but it hasn't changed, other than started a whole new load of errors, which are not WA related! Xampp Mysql not starting now - I think it might be a Windows update issue, as others are having the same issue with xampp.
Cheers
Chris
I've updated to the latest version of DW and have no issues, so maybe Xampp is your issue.
PaulBeta Tester
What php ver have you installed?
Sweens
I upgraded xampp to php 7.4 and it now works.
Phew!
