Can't figure out the operator like BETWEEN, coma seperated value etc in advance query builder
Thread begun 4/20/2020 8:48 am by Rokon | Last modified 4/20/2020 5:44 pm by Ray Borduin | 2034 views | 11 replies |
Rokon
Hello
I am having some trouble with the advance sqli query builder. I need to filter my records by passing url variable with coma separated value like
bookID=1,20,25 etc and also another with the BETWEEN like bookID=2-5 but could not figure it out on the builder.
Please help.
That probably can't be done with the builder. Some complex queries still have to be written by hand.
Rokon
Dear Ray
Please give me an example of a query as like below;
$mainHadith = new WA_MySQLi_RS("mainHadith",$hadithbd,10);
$mainHadith->setQuery("SELECT hadithmain.HadithID, hadithmain.CheckStatus, hadithmain.BookID, hadithmain.chapterID, hadithmain.SectionID, hadithmain.HadithNo, hadithmain.ArabicHadith, hadithmain.ArabicHadithNew, hadithmain.BanglaHadith, hadithmain.EnglishHadith, hadithmain.HadithNote, hadithmain.HadithActive, hadithmain.HadithStatus, hadithbook.totalHadith, hadithbook.BookNameBD, hadithchapter.ChapterBG, hadithchapter.ChapterAR, hadithchapter.ChapterEN, hadithexplanation.explanation, hadithsource.SourceNameBD, hadithsource.SourceNameEN, hadithstatus.StatusBG, rabihadith.rabiBangla, rabihadith.rabiEnglish, hadithsection.SectionBD, hadithsection.SectionEN FROM hadithmain LEFT OUTER JOIN hadithbook ON hadithmain.BookID = hadithbook.BookID LEFT OUTER JOIN hadithchapter ON hadithmain.chapterID = hadithchapter.chapID LEFT OUTER JOIN hadithexplanation ON hadithmain.HadithID = hadithexplanation.hadithID LEFT OUTER JOIN hadithsource ON hadithmain.SourceID = hadithsource.SourceID LEFT OUTER JOIN hadithstatus ON hadithmain.HadithStatus = hadithstatus.StatusID LEFT OUTER JOIN rabihadith ON hadithmain.RabiID = rabihadith.rabiID LEFT OUTER JOIN hadithsection ON hadithmain.SectionID = hadithsection.SectionID WHERE hadithmain.HadithActive = 1 AND hadithmain.HadithNo = ? HAVING hadithmain.BookID = ? ORDER BY hadithmain.HadithNo ASC");
$mainHadith->bindParam("i", "".(isset($_GET['hadith'])?$_GET['hadith']:"") ."", "-1"); //WAQB_Param1
$mainHadith->bindParam("i", "".(isset($_GET['book'])?$_GET['book']:"") ."", "-1"); //WAQB_Param2
$mainHadith->execute();
Here I need to filter the hadithmain.HadithNo by passing a GET value called $mainHadith->bindParam("i", "".(isset($_GET['hadith'])?$_GET['hadith']:"") ."", "-1"); //WAQB_Param1
I need to send search query like index.php?hadith=1,5,10 etc
And in another search I need to get result of in between value from the same filed of hadithmain.HadithNo
Thanks in advance
Try:
$mainHadith->bindParam("il", "".(isset($_GET['hadith'])?$_GET['hadith']:"") ."", "-1"); //WAQB_Param1
adding the "l" to the parameter tell it that you are passing an "integer list" and not a single integer.
Rokon
  Try:
After changing and passing value to url like index.php?hadith=1,2 it shows
There is an error in your SQL syntax.
Sorry I forgot you have to change the comparison too... Instead of:
it should be:
hadithmain.HadithNo IN (?)
If you supply a url and copy of the page it would help me ensure I'm giving the correct advice.
Rokon
it should be:
Yes now it works! Thanks a lot.
Little more guide is needed for the BETWEEN result is needed please.
Rokon
  Try:
You can have a look at http://new.hadithbd.com/hadith/filter/?hadith=12&book=22
login detail in private
It looks like it is working now.
Rokon
Yes is working with coma separated value like http://new.hadithbd.com/hadith/filter/?hadith=12,14&book=22 and many many thanks for your support
& I have little more to solve here which is the query for the BETWEEN value like
http://new.hadithbd.com/hadith/filter/?hadith=12-14&book=22
so that it will bring all result between 12 to 14
Pls help
