Recordsets which have disappeared from the bindings tab
Thread begun 4/19/2020 7:59 pm by cal114936 | Last modified 6/30/2021 9:30 am by Ray Borduin | 1010 views | 3 replies |
cal114936Beta Tester
I created recordsets which have disappeared from the bindings tab. and may not be accessed from the server behaviors tab either. I recreated a recordset and it appears fine now. How do I get DW to read the other recordsets?
The ones that aren't showing have an extra space character....
->setQuery( "
instead of
->setQuery("
Remove the space and they should show up again.
SCar87011738
Hello Ray,
I had the same problem. Thanks for your reply.
Just out of curiosity: why this happened? Perhaps it is due to migrating from DB1 to DB2?
TIA
tony
I'm not really sure. Maybe it was the version of Dreamweaver that was used to originally create the recordsets had a slightly different syntax. So far you two are the only ones to report the issue and I haven't been able to reproduce the cause.
