Odd encoding issue
Thread begun 4/15/2020 12:08 pm by Justin@AdventDesign | Last modified 4/15/2020 1:07 pm by Ray Borduin | 749 views | 1 replies |
Justin@AdventDesign
Odd encoding issue
I have a website built from a template where I've implemented a custom CMS built with dataassist.
I'm having an odd issue with URL encoding. I have a field to store a youtube URL.
On the page, if I simply insert <?php echo($rsHomes->getColumnVal("videoembed")); ?> it displays the URL properly. However, if I insert the exact same code in the <div class="play-button" data-src="<?php echo($rsHomes->getColumnVal("videoembed")); ?>"><i class="hc-play"></i></div> as the template lays out, it returns https:&#x2F;&#x2F;youtu.be&#x2F;QKzHJ4j6x-8 in the code (replaces slashes).
BTW I tried swapping the inner double quotes for single quotes, but no dice. How do I get it to return the proper code with slashes?
Here's the page, if it helps: https://schrockhomes.com/homes-for-sale/detail.php?id=37
Try using:
<?php echo($rsHomes->getColumnVal("videoembed",false)); ?>
The code has built-in cross-site scripting protection that encodes special characters, but adding the false at the end will disable that.
