Having problem to show Master and child table data
Thread begun 4/15/2020 2:12 am by Rokon | Last modified 4/15/2020 10:31 am by Ray Borduin | 2190 views | 6 replies |
Rokon
I have two table where in one table I have the book category and in another table I have the books name like as below
>>category table
catID
Cat Name
>>books table
bookID
catid
bookName
My output need in a repeat region on the page like below;
Cat Name A
- bookName1
- bookName 2
Cat Name B
- bookName 3
- bookName 4
I could not figure out how to do this join query so that in my final output I can show data like this, Pls help.
Use two recordsets and filter the child recordset with the id from the parent.
Then do a repeat region on the parent recordset on the page.
After that is applied, manually move the child recordset code inside of the repeat region for the parent.
Now add a repeat region for the child recordset inside of the other repeat region.
Rokon
Now add a repeat region for the child record set inside of the other repeat region.
I did like this but the problem arise that on the child it shows always the same record inside all the parent repeat like as below and not changing the books base on the Cat Name.
Cat Name A
- bookName1
- bookName 2
- bookName 3
Cat Name B
- bookName1
- bookName 2
- bookName 3
That means that the child recordset isn't inside of the repeat region or isn't filtered by the parent recordset properly. I'd have to see a copy of the page to know which.
Rokon
The parent query is
$booksections = new WA_MySQLi_RS("booksections",$hadithbd,0);
$booksections->setQuery("SELECT books_type.btypeID, books_type.bookCat, Count(books_name.booktype) AS Countbooktype, books_name.booktype FROM books_type LEFT OUTER JOIN books_name ON books_type.btypeID = books_name.booktype WHERE books_name.Active = 1 GROUP BY books_name.booktype ORDER BY books_name.booktype ASC");
$booksections->execute();
The child query is
$booksname = new WA_MySQLi_RS("booksname",$hadithbd,0);
$booksname->setQuery("SELECT books_name.bookID, books_name.booktype, books_name.Book_nameBD, book_writter.writter_nameBN FROM books_name LEFT OUTER JOIN book_writter ON books_name.writterID = book_writter.wrID WHERE books_name.booktype = ? ORDER BY books_name.booktype ASC, books_name.bookID ASC");
$booksname->bindParam("i", "".($booksections->getColumnVal("booktype")) ."", "-1"); //WAQB_Param1
$booksname->execute();
The body is
<div class="row">
$wa_startindex = 0;
while(!$booksections->atEnd()) {
$wa_startindex = $booksections->Index;
<div class="list-group col-sm">
<div class="list-group-item list-group-item-action active">
<span class="badge badge-pill badge-light float-left"> <i class="fas fa-box-open"></i> <?php echo($booksections->getColumnVal("btypeID")); ?> </span>
<span class="text-center text-white ml-3"><?php echo($booksections->getColumnVal("bookCat")); ?></span> <span class="badge badge-warning text-white float-right"><?php echo($booksections->getColumnVal("Countbooktype")); ?></span>
$wa_startindex = 0;
while(!$booksname->atEnd()) {
$wa_startindex = $booksname->Index;
<a href="#" class="list-group-item list-group-item-action"><?php echo($booksname->getColumnVal("Book_nameBD")); ?> - <?php echo($booksname->getColumnVal("writter_nameBN")); ?></a>
</div> <?php
$booksname->moveNext();
$booksname->moveFirst(); //return RS to first record
unset($wa_startindex);
unset($wa_repeatcount);
$booksections->moveNext();
$booksections->moveFirst(); //return RS to first record
</div>
</div>
Copy and paste the child recordset code in code view inside of the repeat region for the parent recordset so that it is re-generated each time it is displayed. It looks like you missed that step.
Rokon
Yes, once copy the query inside the repeat region then it works. Thanks.
