max_user_connections error and now 500 errors
Thread begun 4/09/2020 1:27 pm by Justin@AdventDesign | Last modified 5/22/2020 9:34 am by Ray Borduin | 2635 views | 8 replies |
Justin@AdventDesign
Older site. Front end uses all mysqli, but backend is old and was still using mysql. Client started getting a 'max_user_connections' error this AM. Suspect based upon some other things password for DB connection may have been compromised. Updated passwords and changed connection from pconnect to connect, as suggested in other threads.
Appeared to be working fine, but now on some update pages, getting a 500 error when trying to update data. Page loads fine so it's connecting to the database upon load, but freezes. Adding error reporting code doesn't return anything.
Front end that uses mysqli works fine... until I freeze in the backend with the dataassist pages, then site won't load even the home page.
PHP version is 5.5.36.
I'm sure this is really vague, but looking for some troubleshooting direction.
Justin@AdventDesign
A few more details.... I'm able to write to the DB with some pages, but not with others. I updated the security assist page settings, as I found it was improperly coded, but that appears consistent on both pages.
When I attempt to update the record, the page freezes for a long period and then shows the 500 error. When this happens, it appears to crash the entire site as I can't even access the home page or I get the same error.
I've reached out to the host but base level support is scratching their head and has escalated it up the chain. Just wondering if you have any thoughts from your end.
There is probably an infinite loop of some sort on the page that throws the error. I'd need a copy of the page to possibly spot it. Better yet FTP access and a url to reproduce the issue so I can add debug code and track it down properly.
Justin@AdventDesign
It would appear to be something specific to the host account. I have a sister site that is a near identical match to this one. I've made the same connection and security assist changes on that site, and it still works fine. I've attached both the page on the site with the problem (tbl_product_update.php), and the similar page from the sister site (tbl_product_update_works.php) that is working properly. Save for the addition of a field and corresponding code for that, the pages are identical.
However, I installed the page that works on the sister site onto the site with the problem, and it experiences the same freeze issue. Therefore, I think the problem exists outside the page itself.
See PM
This is an odd one. It does appear to be a corrupted database of some sort.
The SQL statement that is trying to run when it times out is:
UPDATE `tbl_product` SET `module` = 'product', `title` = 'Stratus Spinner, Blue', `subtitle` = '', `sku` = 'HH127', `intro` = '', `detail` = '', `category_id` = '', `subcategory_id` = '', `display_id` = '3', `image` = '', `sort` = '', `publish` = '1', `dateinsert` = '2019-01-04 00:00:00', `dateupdate` = '2020-04-10 00:00:00', `slug` = '', `featured` = '', `new` = '1', `outofstock` = '1', `limitedstock` = '', `artgroup` = '', `relatedonly` = '', `keywords` = '', `datestart` = NULL, `datestop` = NULL, `author` = '', `file` = '', `link` = '', `videoembed` = ' ', `weight` = '0.00', `price` = '69.00', `percent` = '10', `priceeach` = '0.00', `preprice` = '0.00', `filetype` = '', `prodsize` = '89.5"h x 19"w x 19"d', `relatedid` = '', `detail1` = '', `detail2` = '', `detail3` = '', `detail4` = '', `detail5` = '', `minimum` = '2', `case` = '1', `comingsoon` = '', `comingwhen` = '' WHERE `id`='1514'
It is a simple one row update, so it shouldn't cause an issue. I also tried running:
REPAIR TABLE tbl_product
That also times out with a 500 error.
Maybe try running the repair from phpMyAdmin. I'll try a few more things, but it looks like the database itself is the issue here.
I duplicated the tbl_product table as tbl_product2. Then I tried running the update against that table and it ran without issue.
I think you can simply delete the tbl_product table and rename the tbl_product2 table to tbl_product and it would resolve this issue. I tried renaming the tbl_product table but that times out as well. I didn't want to delete the table from my end since that seemed risky.
verify the data in the tbl_product2 table is complete and accurate and then try dropping the corrupt table and rename the new one.
Justin@AdventDesign
Thanks Ray. You were spot on with the problem. I had a heck of a time wrapping it up, as everything I would try to do on cpanel that involved that table would freeze. However, working with the host, we got it sorted out.
I appreciate your help as always. Sent a donation.
Justin@AdventDesign
Ray, this issue has again popped up and I'm at a loss for how we're ending up in the same boat. We're getting the exact same problem. Making a change to the database via our backend pages freezes the page and kicks 500 errors on any page that utilizes the product table. I don't know if some way in which we're writing to the database is corrupting it. I wouldn't think so, as it's all based on long used webassist code. Have you ever had an issue with a database repeatedly become corrupted? Any ideas on how to troubleshoot would be appreciated.
I think it is more likely to be a hardware issue and a bad hard drive on the server. I'd suggest moving to a new server before a more catastrophic error occurs.
