image width check
Thread begun 4/07/2020 10:53 am by Jamie | Last modified 4/10/2020 11:26 am by Ray Borduin | 3480 views | 17 replies |
Jamie
image width check
Hi Ray
Is there a way to user the server validations to check and make sure that an image file is at least a certain width or would it need to be done with js?
Cheers
You can do it. The file upload server behavior will have the width and height available for image uploads. You can use that with number validation to add restrictions. You just have to manually move the upload code above the validation code.
Jamie
something like the attached?
It looks like that would work.
Jamie
OK
$WAFV_Errors .= WAValidateNM(WADFP_getImageWidth((isset($_FILES["ProductThumbnail"]))?$_FILES["ProductThumbnail"]:"") . "",1900,3000,"",",.",true,5);
Keeps failing validation with an image of 1920px width - when I comment out this validation, the image uploads without any problem at all
Can I get a url to reproduce and FTP access? I'll debug and see what is going on.
Jamie
sure..see PM and thanks
I see... since you are validating the $_FILES["ProductThumbnail"] value directly, you didn't need to move the file upload code above the validation. In fact, that deletes the temp file and caused the validation to fail.
I moved the file upload code back down below the validation and that seems to have resolved this issue.
Jamie
Thats great...many thanks Ray
Jamie
Sorry but it wont allow a blank entry for some reason
$WAFV_Errors .= WAValidateNM(WADFP_getImageWidth((isset($_FILES["ProductThumbnail"]))?$_FILES["ProductThumbnail"]:"") . "",2000,"","",",.",false,5);
