Problem with Registration form bindings.
Thread begun 4/06/2020 10:42 am by balexander389215 | Last modified 4/10/2020 8:17 am by Ray Borduin | 4437 views | 24 replies |
balexander389215
I've created a registration form and everything works fine, except... The input for Website. If the website and copied from an address bar and pasted into the form all is fine, if it is typed in including the http:// it works but if it is typed in with just www.etc then I get a 404 error and the address bar shows:
my_website/target_website.
For example when I create a new listing and type in a well know web address then check the database it shows up as typed in. www.webassist.com
Now when I go to the Profile it shows the link www.webassist.com but clicking on it produces the address:
http://www.songwritersinconcert.com/www.webassist.com
Here is the coding creating the link.
<a href="<?php echo($profileVs->getColumnVal("Website")); ?>" target="_blank"><?php echo($profileVs->getColumnVal("Website")); ?> </a>
Somehow it is adding the base website if http:// is not added.
If I had originally typed in http:// it would have worked and connected to your site.
Most people don't type in the http:// when entering their website. Any idea of what needs to be changed to allow a simple www to work?
Unless I'm missing something, this sounds like a website configuration issue and not an issue with your web page. You may want to bring this up to your website hosting provider.
If you give me the url to enter to see the problem I may be able to help more. It sounds like a mis-configured .htaccess file.
balexander389215
If you check out here:
http://www.songwritersinconcert.com/profileVs.php?id=383
Now hovering over the link without clicking shows the destination address to be the one strqange one shown above.
There really isn't anything in the htaccess file.
# php -- BEGIN cPanel-generated handler, do not edit
# Set the “ea-php73” package as the default “PHP” programming language.
<IfModule mime_module>
AddHandler application/x-httpd-ea-php73 .php .php7 .phtml
</IfModule>
# php -- END cPanel-generated handler, do not edit
A link without http:// or https:// will always be considered page relative by your browser. If this is from an input form then you would have to add the http:// if it was missing.
If you post your file or the code you use to generate the link then I could help you with a quick solution in php.
balexander389215
Yes I see what you mean.
In the bindings instead of:
<?php echo((isset($_POST["Website"]))?$_POST["Website"]:""); ?>
try:
<?php echo(!empty($_POST["Website"])? ((strpos(strtolower($_POST["Website"]), "http") !== 0)?"http://".$_POST["Website"]:$_POST["Website"]):""); ?>
Another simple solution is to use <input type="url"> and then most browsers will automatically require them to add the http:// or https:// before the form submits.
balexander389215
Thanks Ray, though I'm a little confused. The binding looks like this.
$InsertQuery->bindColumn("Website", "s", "".((isset($_POST["Website"]))?$_POST["Website"]:"") ."", "WA_DEFAULT");
There is no php echo to replace so I'm not sure just where the php echo function should start and end. I keep trying different things but get syntax error.
If you open the Server Behavior it will have the syntax I mentioned. If you want to update the code directly it would be:
$InsertQuery->bindColumn("Website", "s", "".(!empty($_POST["Website"])? ((strpos(strtolower($_POST["Website"]), "http") !== 0)?"http://".$_POST["Website"]:$_POST["Website"]):"") ."", "WA_DEFAULT");
balexander389215
I get a syntax error. I also figured out what you meant on the other one where I was to make the change in the Insert record bindings so I tried that and also got a syntax error.
balexander389215
I got it in without the syntax error and tested it out. Unfortunately however it did not work. The entry in the database is still without http and the same error occurs when I try to open the link.
