Payments Pro with Express Checkout
Thread begun 4/04/2020 12:04 pm by TroyD | Last modified 4/08/2020 12:01 pm by Ray Borduin | 2386 views | 6 replies |
TroyD
Ray,
Just to confirm.
With Payments Pro, both confirm.php and pp_confirm.pp have the Store Summary, Store Details and Send Emails behaviors on them? I assume they should match in each case, other than the trigger?
So, if they pay directly with a credit card, confirm.php is used but if they pay with paypal, pp_confirm.php is used?
Also, what to I bind to for the txn_id (Transaction ID) to be recorded in the database in each case?
For the stand alone express checkout I'm using
$ConditionalQuery->bindColumn("txn_id", "s", "".WA_PP_ECO_GetValue($WA_PP_ECO_DoResult, "TransactionID")  ."", "WA_DEFAULT");
on the pp_confirm.php so I assume that will work for Payments Pro. But what about the confirm.php page. The same?
Thanks,
Troy
TroyD
Ray,
Please ignore my post above. I figured it out over the weekend. Thanks! TroyD
TroyD
I might have spoken too soon here. I thought I had figured out both the confirm.php and the pp_confirm.php bindings for Transaction ID. And actually, they both work to record the Transaction ID into the database column txn_id.
However, the direct payment process is creating an error_log on the server. I'm not sure it has anything to do with this but it points to it I think.
If I do a test transaction using PayPal Express Checkout, there is no error. However, if I use the direct payment, it generates the following php warning in the error_log file. But the transaction all goes through ok and all emails are sent.
[07-Apr-2020 13:04:59 America/Chicago] PHP Warning:  A non-numeric value encountered in /home/domainname/pathtohtml/WA_eCart/Adv_CO_Scripts/PP_DirectPayment_PHP.php on line 335
When I look at line 335 of the PP_DirectPayment_PHP.php file, I see the variable $paramName, which is referenced above line 335, in the function PP_DirectPayment_Result where it is created in a switch statement. The only response I am using from that list of bindings is to insert the Transaction ID into the order table. So I figured I should check to see if it isn't the correct use of that binding or something else is going on.
Here is what that line in the "Store Cart Summary" (on the confirm.php page) behavior looks like.
$ConditionalQuery->bindColumn("txn_id", "s", "".PP_DirectPayment_Result("Transaction ID")  ."", "WA_DEFAULT");
Also, I captured the session for PP_DirectPayment. I noticed that the only part that does not include the "psi:type=" is the <TransactionID> in the xml response, but since this all comes from PayPal, maybe is has nothing to do with it. Basically, I was trying to figure this out myself but so far, I'm not finding the problem.
Thanks,
TroyD
That is just a warning and it can probably be ignored if everything works. However I can still probably fix it. Try changing that line from:
if (strpos($SessionVal,"<".strtolower($paramName))>=0 && strpos($SessionVal,"</"+strtolower($paramName))>=0) {
if (strpos($SessionVal,"<".strtolower($paramName)) !== false && strpos($SessionVal,"</"+strtolower($paramName)) !== false) {
TroyD
Thanks Ray, but that did not fix the warning. Same warning but now it prevents the Transaction ID from being inserted into the database.
I reversed the change and tried again. Got the warning of course, but the Transaction ID was correctly inserted into the db.
If it's just a warning that can be ignored, I won't worry about it for now but if you have any other thoughts, I will try them.
If I see any other issue popup, I may revisit it.
Thanks,
TroyD
I'm not sure how it could have the same error and cause it to not work. If you have time to do a screen sharing session I can debug it and get it fixed with you.
TroyD
Sure thing. See PM
