CRASH: "Preview resonsive design option", "Smartphone, Tablet, Desktop" selector in "Shoppoing cart III tutorial"
Thread begun 3/28/2020 8:41 am by yogastudents362523 | Last modified 3/30/2020 11:30 am by Ray Borduin | 2133 views | 6 replies |
yogastudents362523
Hello,
CRASH and closure of Dreamweaver.
This tutorial
http://www.webassist.com/tutorials/Add-a-shopping-cart-III-eCommerce-Series
Part that says:
"Choose one of three options in the eCart Display Manager to preview your chosen design options: Smartphone, Tablet, and Desktop."
My machine hangs on touching any of the three … then Dreamweaver crashes and quits ignominiously.
Windows 10, Dell Inspiron 17 (2000 series)
Will provide if you need more info.
Enjoying tutorials.
Thank you,
KB
I've updated the build to address this issue. I couldn't reproduce it, but I added a delay that might be enough to keep dreamweaver from crashing. Please reinstall and see if that fixes the problem.
yogastudents362523
It now does not crash, which is an improvement.
It now just hangs.
I actually go into Theme-It. I touch every single button, and movable selectable object as if I am a designer searching for a good "look".
Then when I try to "Finish", the button does not work. Better than a crash, though.
Hope you can reproduce.
KB
,Toi be clear, the Cancel button still works, so I can continue with other stuff, hopefully
You can always change the colors in Dreamweaver by updating the .css files after running the wizard.
I was not able to reproduce the crash, but I only made a few changes. If you want to do screen sharing to investigate this further, please post back with a phone number and good time to call in the private area of a reply.
yogastudents362523
SInce it is only happening to me, I do not think it worth all that trouble, just for this. If it was happening to someone else … … …
I'm unable to reproduce it and haven't gotten any other reports. I think if you are OK with making the updates in the CSS after application then this one can be ignored and just don't use the Theme It option.
yogastudents362523
I am quite OK with that, and agree entirely,
KB
