while executing onClick in WA AppBuilder.htm
Thread begun 9/17/2009 4:53 pm by fred306789 | Last modified 9/21/2009 1:07 pm by fred306789 | 7564 views | 10 replies |
fred306789
I don't get it, what is up with all these Java errors. I am trying to use the Data Assist wizard in CS4 and getting these errors: while executing onClick in WA AppBuilder.htm error 2774.
Any Idea what I need to do.
Jimmy Wu
With Dreamweaver closed, try deleting the WinFilecache-########.dat or MacFileCache-########.dat, depending on your operating system, file from the following location:
WinXP
-DW8
--C:\Documents and Settings\<Your User Name>\Application Data\Macromedia\Dreamweaver 8\Configuration
-DWCS3
--C:\Documents and Settings\<Your User Name>\Application Data\Adobe\Dreamweaver 9\Configuration
-DWCS4
--C:\Documents and Settings\<Your User Name>\Application Data\Adobe\Dreamweaver CS4\en_US\Configuration
Win Vista
-DW8
--C:\Users\<Your User Name>\AppData\Roaming\Macromedia\Dreamweaver 8\Configuration
-DWCS3
--C:Users\<Your User Name>\AppData\Roaming\Adobe\Dreamweaver 9\Configuration
-DWCS4
--C:\Users\<Your User Name>\AppData\Roaming\Adobe\Dreamweaver CS4\en_US\Configuration
Mac OSX;
-DW8
--Hard disk: Users: <Your User Name>: Library: Application Support: Macromedia: Dreamweaver 8:Configuration
-DWCS3
--Hard disk: Users: <Your User Name>: Library: Application Support: Adobe: Dreamweaver 9: Configuration
-DWCS4
--Hard disk: Users: <Your User Name>: Library: Application Support: Adobe: Dreamweaver CS4: en_US: Configuration
(Please note that <Your User Name> Should be replaced with the User name you use to log into your computer)
Also, please make sure that you have the most recent version of our extensions installed.
NOTE:
On Windows Computers, The AppData or Application Data folders may be set to be hidden.
To View Hidden Folders in Windows Vista:
1) In The Windows Explorer, Click the "Organize" button
2) Select "Folders And Search Options"
3) Select the "View" tab
4) Click the "Show Hidden Folders And Files" radio button.
To View Hidden Folders in Windows XP:
1) On the Tools menu in Windows Explorer, click Folder Options.
2)Click the View tab.
3) Under Hidden files and folders, click Show hidden files and folders.
fred306789
Thank you
Thak you very much for your help, I will give that a try.
Jimmy Wu
Let me know how it goes.
fred306789
I will thanks
I will thanks....
fred306789
Well the Java error went away, however now wen I run the login screen I am getting a 500 server error.
I am running Vista with IE and I cannot get the script debug to turn on? Anyway I checked the connection string and the test to the Access DB passes ( I am using ASP VB Script.).
So I tried to add a few response.write error levels and they do not even show up. Here is the code for the pages:
Connection string:
' FileName="Connection_ado_conn_string.htm"
' Type="ADO"
' DesigntimeType="ADO"
' HTTP="true"
' Catalog=""
' Schema=""
Dim MM_email_Con_STRING
MM_email_Con_STRING = sDSN = "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & Server.MapPath("/access_db/aspEmail.mdb")
Login Script:
<%@LANGUAGE="VBSCRIPT" CODEPAGE="1252"%>
<!--#include file="Connections/email_Con.asp" -->
<!--#include file="WA_SecurityAssist/Helper_VB.asp" -->
If (Request.ServerVariables("Request_Method") = "POST") Then
Dim WA_AuthParameter100 : Set WA_AuthParameter100 = Server.CreateObject("Scripting.Dictionary")
WA_AuthParameter100.Add "connection" , MM_email_Con_STRING
WA_AuthParameter100.Add "tableName" , "Mail"
WA_AuthParameter100.Add "columns" , Split("Email"&WA_Auth_Separator&"PasswordEnc", WA_Auth_Separator)
WA_AuthParameter100.Add "columnValues" , Split("" & cStr(cStr(Request.Form("username"))) & ""&WA_Auth_Separator&"" & cStr(cStr(Request.Form("userpassword"))) & "", WA_Auth_Separator)
WA_AuthParameter100.Add "columnTypes" , Split("200"&WA_Auth_Separator&"200", WA_Auth_Separator)
WA_AuthParameter100.Add "columnSizes" , Split("100"&WA_Auth_Separator&"50", WA_Auth_Separator)
WA_AuthParameter100.Add "sessionColumns" , Split("ID", WA_Auth_Separator)
WA_AuthParameter100.Add "sessionNames" , Split("ID", WA_Auth_Separator)
WA_AuthParameter100.Add "successRedirect" , "freeresources/index.asp"
WA_AuthParameter100.Add "failRedirect" , ""
WA_AuthParameter100.Add "gotoPreviousURL" , True
WA_AuthParameter100.Add "keepQueryString" , True
WA_AuthenticateUser WA_AuthParameter100
End If
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<title>Log In</title>
<link href="WA_SecurityAssist/styles/Refined_Pacifica.css" rel="stylesheet" type="text/css" />
<link href="WA_SecurityAssist/styles/Arial.css" rel="stylesheet" type="text/css" />
</head>
<body>
<div id="LogInContainer" class="WAATK">
<form action="<% If(Request.QueryString <> "")Then Response.Write(CStr(Request.ServerVariables("SCRIPT_NAME"))&"?"&Server.HTMLEncode(Request.QueryString)) Else Response.Write(CStr(Request.ServerVariables("SCRIPT_NAME"))) %>" method="post" name="WAATKLogInForm" id="WAATKLogInForm">
<h1>Log In</h1>
<table class="WAATKDataTable" cellpadding="0" cellspacing="0" border="0">
<tr>
<th>User name</th>
<td><input type="text" class="WAATKTextField" name="username" value="" /></td>
</tr>
<tr>
<th>Password</th>
<td><input type="password" class="WAATKTextField" name="userpassword" value="" /></td>
</tr>
</table>
<div class="WAATKButtonRow">
<input type="Submit" name="LogIn" id="LogIn" value="Log In">
</div>
</form>
</div>
</body>
</html>
Thanks for your help.
This is a generic error message that your webserver is returning. To determine what the problem is a more meaningful error message will be needed. To enable the more advanced error messaging in IIS 7 for Vista you will need to do the following:
1) Go to Control Panel > Administrative Tools
2) Open the IIS control panel and open the ASP option
3) At the top of the ASP control area select Display: Friendly Names
4) Now go down to the Compilation area and expand Debugging Properties
5) In debugging properties make sure to set Enable Client -side Debugging, Enable Server -side debugging, and Send Errors to Browser to TRUE. Make sure to click the Apply on the right side of the page.
6) After setting the debugging you must go back to the IIS control panel and using the controls on the right side restart the server.
This will enable debugging info to display when an error occurs. This should be turned on while testing and should not be left enabled for a live server.
fred306789
Thank you for your response, however I do not have control over the server. I have Virtual hosting account from Go-daddy and no control on the settings.
So i found one of the treads here in this forum stating to try just a record set which reads data from the Access database. I did that ( code below ) and still the same problem?
This is very strange because I have another hosting account Identical to this one and loaded an e commerce shopping on that account and that one works right out of the box with no problem.
The connection string I use is this: sDSN = "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & Server.MapPath("/access_db101/**********************.mdb").
The connection string for the one I have problem with is: MM_Con_STRING = sDSN = "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & Server.MapPath("/access_db101/************.mdb") with a dim declaration of Dim MM_Con_String
Here is the Recordset code I used: Note I connect within Dreamweaver fine when I test the connection, however; I get the 500 server error when I load this page in the browser.
<!--#include file="Connections/Con_Con.asp" -->
Dim Recordset1
Dim Recordset1_cmd
Dim Recordset1_numRows
Set Recordset1_cmd = Server.CreateObject ("ADODB.Command")
Recordset1_cmd.ActiveConnection = MM_email_Con_STRING
Recordset1_cmd.CommandText = "SELECT * FROM Mail"
Recordset1_cmd.Prepared = true
Set Recordset1 = Recordset1_cmd.Execute
Recordset1_numRows = 0
<html>
<head>
</head>
<body>
<p><%=(Recordset1.Fields.Item("Email").Value)%>
</p>
<p><%=(Recordset1.Fields.Item("DateTime").Value)%></p>
<p><%=(Recordset1.Fields.Item("FirstName").Value)%>
<%=(Recordset1.Fields.Item("LastName").Value)%></p>
<p>
<%=(Recordset1.Fields.Item("PasswordEnc").Value)%></p>
</body>
</html>
Recordset1.Close()
Set Recordset1 = Nothing
fred306789
Now after I deleted all and created a database I get the ADODB.Command error '800a0bb9' Error.
Why Is it that you guys use this "ADODB.Command" stuff? Why are we not using the
Set cnn=Server.CreateObject("ADODB.Connection")
Set rs = Server.CreateObject("ADODB.RecordSet")
This worked for years, how can I remove the "ADODB.Command".
Please send a copy of your page in a zip file and the exact error including the line number so I can look at the code generating the error.
