Tables : none - connection script question
Thread begun 3/25/2020 1:38 pm by lr_leal239405 | Last modified 4/06/2020 1:28 pm by Ray Borduin | 3829 views | 10 replies |
lr_leal239405
I think we went thru this before but I get the Tables : none when trying to create a Recordset. The website is redirected to using the https://www from the php.ini. There are tables of course. The connection script is below and also the PHP info.
Thanks.
This is usually an issue with the dreamweaver site definition and the testing server website URL setting. Check those to see if they look right and use the Test button in the connection dialog to get a full error.
If you still have issues you can export the site definition and attach it to a reply so I can test and debug it on my end.
lr_leal239405
They look correct to me. attached is site definition file.
Dreamweaver error:
HTTP Erro 404 File Not Found. Here are some possible reasons for the problem:
1) There is no testing server running on the server machine.
2) The testing server specifified for this site does not map to the https://www.sangiacomo-presses.com/_mmServerScripts/MMHTTPDB.php URL: Verify that the URL Prefix maps to the root of the site
Which connection? The exhibitions_cx connection seems to be working for me. I just downloaded the live version and tested it.
lr_leal239405
yes. That's the right one. I don't get tables to show when trying to add a Recordset or view an existing one with the server behaviors. So, maybe it's only local to me? what to do next? I did just change hosting companies. Could that have anything to do with it?
Maybe try reinstalling DataBridge. It is possible that a Dreamweaver update or other extension overwrote the proper connection files. If that doesn't work you would have to call me and we could look over it in a screen sharing session.
lr_leal239405
ok. I may need that if it doesn't work,
Just call the number at the bottom of the site, or post your number in the private area and I can call you if it continues to be an issue.
lr_leal239405
I'm looking to see how to 'Uninstall'. I installed with using ExManCmd, but I've never had to uninstall. Do you know how? Also, will the re Install work if Dreamweaver has made an update? Thanks.
lr_leal239405
Actually I just ran the reinstall and it looks like it's just doing that... reinstalling. Hopefully the connections sees the databases again.
