PEAR
Thread begun 3/21/2020 6:25 am by yogastudents362523 | Last modified 3/24/2020 12:26 pm by Ray Borduin | 4925 views | 21 replies |
yogastudents362523
PEAR
I have created a Contact Page.
Universal Email should be sending it out using PEAR.
I see nowhere to put any settings for a "Path to PEAR", and emails are not being sent.
Is there something I am missing in the UniEm template?
All my details seem to be correct.
Thank you,
KB
UPDATE:
Firstly:
If it helps any, this is the code it has created:
if (true) { //WA Universal Email
$Email = new WA_Email("evaluation_2");
$Email->From = "".((isset($_POST["Email_Address"]))?$_POST["Email_Address"]:"") ."";
$Email->Method = "smtp";
$Email->Host = "smtp.xxxxxxl.com";
$Email->Port = "xxx";
$Email->SMTPAuth = true;
$Email->Username = "xxxxxxxx";
$Email->Password = "xxxxxxxxxxxxxxxxxx";
$Email->addTo("xxxxxxxxxxxxxxxx");
$Email->BodyFile = "evaluation_thanks.php";
if (function_exists("rel2abs") && $Email->Redirect) $Email->Redirect = $Email->Redirect?rel2abs($Email->Redirect,dirname(__FILE__)):"";
for ($emailGroup=0; $emailGroup<sizeof($Email->To); $emailGroup++) {
$Email->Subject = "evaluation from: ".((isset($_POST["Full_Name"]))?$_POST["Full_Name"]:"") ."";
$Email->send($emailGroup);
$Email->close();
Secondly
I notied that it did not have includeds at the top, so I tried inserting:
<?php require_once("webassist/email/mail_php.php"); ?>
<?php require_once("webassist/email/mailformatting_php.php"); ?>
<?php require_once("webassist/email/PEAR_Mail_using_SMTP_php"); ?>
But that did not help, so I deleted them
KB
(obviously, there is actual data where I have put xxxxxx)
You just need the one include: webassist/email/WA_Email.php
The others should be removed.
You can turn on debugging with smtp and that will give you information about when and why it is failing.
Authenticated SMTP often won't send email FROM someone other than the logged in sender.
Most likely the FROM has to be set to the same value as the $Email->Username and then you can set the ReplyTo from the form value.
yogastudents362523
I am afraid that has not worked, either.
I made "To" and "From" values the same, and deleted all extraneous file references. .
(Apologies for having posted code earlier. It was v early in morning, and been up all night! Sorry again)
Turn on Debug in the email settings section where you set the server. That will trace the email and provide errors.
yogastudents362523
I did that, but cannot find where the listing was sent
Am trying again
K
First I got a 505 error, then a blank page.
Am trying again.
Got following:
2020-03-21 17:44:20 Connection: opening to smtp.xxxxxx.com:465, timeout=300, options=array ( 'ssl' => array ( 'verify_peer' => false, 'verify_peer_name' => false, 'allow_self_signed' => true, ),)
2020-03-21 17:44:22 Connection failed. Error #2: stream_socket_client(): unable to connect to smtp.xxxxxx.com:465 (Connection refused) [/var/ …. …. /webassist/email/phpmailer/src/SMTP.php line 328]
2020-03-21 17:44:22 SMTP ERROR: Failed to connect to server: Connection refused (111)
SMTP connect() failed. https://github.com/PHPMailer/PHPMailer/wiki/Troubleshooting
Now trying to decipher that gobbledygook
KB
I am in the first instance going to assume that the port is blocked, and am therefore consulting with ISP
It could be a bad host name username or password as well. It fails when trying to connect the smtp server.
yogastudents362523
Hi
I am now getting a message saying:
"extension missing open ssl"
Thank you,
KB
I have run phpinfo, and openssl is definitely installed.
I have tried all combinations of tls, ssl, starttls, and ports 465 and 587
I get the least number of errors with ssl and 465 and with the following code snipper included (seemed better to put just the one line than attach a page that had my login credentials all over it; am tired and don't want to break anything by editing it out).
I read on a PHPmailer forum that it was advisable to insert the underneath line; and it did seem to reduce errors.
<?php echo (extension_loaded('openssl')?'SSL loaded':'SSL not loaded')."\n"; ?>
I will delete if you advise.
But I believe that that is what tells me that SSL is loaded OK.
Since my php and Apache also seem to have the relevant openssl enabled, I am mystified.
Thank you for your kindness,
KB
UPDATE
I am presently very tired, so it is a job to stay coherent.
I cannot recollect how it happened, but I suddely got refusals to load the Contact Form page I am creating because it was attempting to load:
www.www.xxxxxxxxxx.com
My security certificate (QuickSSL from Geotrust) is in fact for:
only for "xxxxxxxxxx.com", without that "www.".
Therefore, I tried inserting the following code snipper immediately before calling Universal Email, and to strip out that "www.":
if(!strstr($_SERVER['HTTP_HOST'],'www.'))
return;
header('HTTP/1.1 301 Moved Permanently');
header('Location: http://'.substr($_SERVER['HTTP_HOST'],4).$_SERVER['REQUEST_URI']);
exit();
This garnered a mild success in that the openssl not open error message went away …
however ...
the only thing to be seen in the browser window was the line:
SSL loaded.
Absolutely nothing else was present. At least the openssl not open error had gone.
I therefore tried introducing the following code snipper to reintroduce the "www":
$url="https://kofibusia.com:8080/href.php?redir=https://www.kofibusia.com";
I now again had a visible contact page, … BUT …
that wretched openssl not loaded error was right back up at the top of the browser window again, although the page with contact form was built.
I am now too tired to mess around with further WebAssist code, but feel that I need to find other instances where this stripping trick might work as the page is being treated.
I perhaps should also try a more efficient method of checking on the "www." code?
I found a snipper from a third party that might provide a test, but it is not wise to do anything else right now.
If you could kindly devote some fresh eyes to this, I would be grateful.
Thank you,
KB
To be clear, I sandwishced UE with code that first stripped the www., and then reintroduced it afterwards. That made the openssl not loaded error disappear, but would not load the page except for the error message at the top saying SSL loaded
Thank you
yogastudents362523
Hi
I just wish to confirm:
When I use the code snippet:
return;
exit();
It removes the error message that says:
but leaves a single line at the top of the browser window that says:
"SSL loaded"
since the contact page will not load, I cannot test what effect that might have had on the attempt to connect through PEAR.
If I remove that code snipper the error about openssl returns.
Thank you,
KB
Delete the line you added:
That is a debug line to see if SSL is loaded and it is causing the page to not load now that ssl works it can be removed.
yogastudents362523
removed
The "Extension missing: openssl" returned immediately.
When I tried reusing the code snippet to removed the "www", the page would not load at all.
Blank screen
I therefore also removed those.
So back to square one with that error
Sorry
KB
