Not getting Grand Total into DB of eCart
Thread begun 3/19/2020 10:30 am by lr_leal239405 | Last modified 3/19/2020 1:57 pm by Ray Borduin | 1129 views | 2 replies |
lr_leal239405
Does the line of code below look correct - the one that should be putting the Shopping Cart Grand Total into the db? because I'm getting 0. I just want to rule that out before I look into other code. Thank you.
$ConditionalQuery->bindColumn("OrderAmount", "d", "".(WA_eCart_DisplayMoney($eCart1, $eCart1->GrandTotal())) ."", "WA_DEFAULT");
WA_eCart_DisplayMoney() is probably adding a dollar sign and causing it to not insert into a numeric field. It should probably just be:
$ConditionalQuery->bindColumn("OrderAmount", "d", "".($eCart1->GrandTotal()) ."", "WA_DEFAULT");
lr_leal239405
ok. thanks. I changed it. hope it works.
