Multiple record update page is updating all records, not just the checked ones
Thread begun 3/19/2020 5:54 am by Mags | Last modified 3/19/2020 10:02 am by Ray Borduin | 1039 views | 2 replies |
Mags
Hi Ray, I have a mySQLI multiple record update page set up but regardless of which records I check, it updates all of them (apart from one, strangely). I've removed and recreated the server behavior several times and tried re-ordering the code on the page, but can't get it to work properly. Would you mind taking a look to see what's causing this? Copy of page is attached.
I think you just have to bind the Archived column to the checkbox. So line 39 will go from:
$UpdateQuery->bindColumn("Archived", "i", "1", "WA_IGNORE");
$UpdateQuery->bindColumn("Archived", "i", "".((isset($_POST["archive"."_".$MultipleUpdateCount]))?$_POST["archive"."_".$MultipleUpdateCount]:"") ."", "WA_IGNORE");
Mags
Got it working, I hadn't set a value on the checkbox...!
