Fatal error: Uncaught Error: Class 'CKEditor' not found in /Applications/ ... /229 Stack trace: #0 {main} thrown in /Application
Thread begun 3/15/2020 8:22 am by Paul | Last modified 3/15/2020 10:11 am by Ray Borduin | 1775 views | 2 replies |
PaulBeta Tester
Created using DA
Receiving this error part way down an update page when run
Fatal error: Uncaught Error: Class 'CKEditor' not found in /Applications/XAMPP/xamppfiles/htdocs/web/db/DEVICE_update.php:229 Stack trace: #0 {main} thrown in /Applications/XAMPP/xamppfiles/htdocs/web/db/DEVICE_update.php on line 229
Page attached.
Any ideas ?
PaulBeta Tester
Resolved
OK, so I found that the create wizard had not include <?php require_once("/webassist/ckeditor/ckeditor.php"); ?> at my page top.
Is this a bug in the current release of DA?
Sometimes it just gets placed too low on the page, which is a Dreamweaver issue. I'll look into it to make sure it isn't something that happens consistently. It is possible there is an issue in the latest build. Adding it manually is a good solution in the meantime when this happens.
