For Power PC users Updating to Latest Version
Thread began 9/17/2009 3:17 pm by Jimmy Wu | Last modified 5/13/2010 3:23 pm by Jimmy Wu | 5345 views | 4 replies |
Jimmy Wu
There is an issue updating to the latest SiteAssist Pro dot release (version 1.0.7) - from build 1.0.6 and prior. We believe the error will only present for Mac Power PC users.
If you experience a javascript error loading the user interface (wacs_wizard.htm will be in the error message), this is the workaround:
After installing 1.0.7, close the Extension manager and Dreamweaver and look in this directory:
Mac OSX;
-DWCS3
--Hard disk: Users: <Your User Name>: Library: Application Support: Adobe: Dreamweaver 9: Configuration: JSExtensions
-DWCS4
--Hard disk: Users: <Your User Name>: Library: Application Support: Adobe: Dreamweaver CS4: en_US: Configuration: JSExtensions
Delete the WASAP_Bundle.bundle file and run the product again.
We apologize for the inconvenience. If you have any problems with accomplishing this, or still experience errors, please let us know and we will assist.
b.otto353573
web person
Did that and it still gave me the same message. What could be wrong?
Jimmy Wu
The next step to take is a little more involved. You can rename the configuration folder to have Dreamweaver recreate it. Close Dreamweaver and go to:
Mac OSX;
-DW8
--Hard disk: Users: <Your User Name>: Library: Application Support: Macromedia: Dreamweaver 8
-DWCS3
-DWCS4
(Please note that <Your User Name> Should be replaced with the User name you use to log into your computer)
Rename the configuration folder to configuration_back. This will have the effect of disabling all of the installed extensions. You should open the extension manager and remove all extensions to clear the extension mangers cache. After removing the extensions you can then reinstall them making sure to download the latest versions from your order history.
toms016390756
Thanks got it to work on my old machine :)
Jimmy Wu
Great to hear it. If you run into any additional issues, feel free to open a new thread.
