php7.3 and mysqli problem
Thread begun 3/11/2020 5:31 am by Marga-NL | Last modified 3/11/2020 8:38 am by Ray Borduin | 1745 views | 3 replies |
Marga-NL
In the WA database panel the tables don't show when opening the database connection. The database connection works fine.
The external sever uses php7.3. Error message when trying to make a new db connection: Your PHP server doesn't have the MySQL module loaded or you can't use the mysql_(p)connect functions.
Can this be solved?
Usually this is an issue with your connection file settings. Specifically the Web URL of the testing server set to the wrong location. If you send me a copy of your exported site definition then I could take a look.
Marga-NL
OK Ray.
Are you testing a mysqli connection? Have you tried using the menu option Site->Advanced->Remove Connection Scripts?
Have you reinstalled the latest version of Data Bridge lately?
I'd try reinstalling the extension to make sure you have the latest version. Then delete your connection scripts and try again. If it still doesn't work then I'll need FTP access to test further. The site definition looks correct.
