My update page is breaking at the html editor, also is there a an editor that will show active urls without requiring user to link them
Thread begun 3/10/2020 10:20 am by jo271221 | Last modified 3/12/2020 10:17 am by Ray Borduin | 2727 views | 9 replies |
jo271221
I have added details in the attachment.
You were missing the html editor include file:
<?php require_once("../webassist/ckeditor/ckeditor.php"); ?>
I don't know of a good way to automatically link urls in text. You might be able to find a custom script on the web to add the links when they are being displayed instead.
jo271221
Thank you, that resolved my issue with the html editor. Now my page is not updating and returns to a blank page. I have copied the code in the private message and also attached a PDF. The server credentials are in original post.
I see it has some pagination code in there however I do not think that is the problem as I believe I had tested it and it worked before adding my design. I normally keep my original, but erroneously deleted it so I cannot go back and look at it.
I did add rows and columns within the form in an effort to make it more friendly and responsive. Does that create a problem?
If you get a blank page, always start by adding this to the top:
ini_set
("display_errors",1);
That will usually give you a better error that you can act on.
jo271221
Thank you, I added the error reported and got this
Fatal error: Class 'WA_MySQLi_Query' not found in /home/mysite/public_html/mydirectory/mypage.php on line 26
It looks like you are missing a necessary include:
<?php require_once('../webassist/mysqli/queryobj.php'); ?>
jo271221
Thank you very much! One last thing, I have a settings option but I do not have 'actions'. I am uploading a screenshot of a website using an older version of the editor with crop, rotate, and other image options.
Can I get a url and steps to view the issue? Do you still have the options when you right-click?
jo271221
All the credentials are on the attached doc as well as the url. Steps in private message.
Those items are now accessed by right-click on the image.
