Send email on condition?
Thread begun 2/28/2020 2:21 am by SCar87011738 | Last modified 2/28/2020 9:20 am by Ray Borduin | 897 views | 1 replies |
SCar87011738
Hello all,
I need to send an email only if a condition is met on my form.
What is the best approach?
1- set the email server behaviour regularly and wrap it with a Show if SB?
2- set a recordset that intercepts a specific form field and use this recordset as a trigger for the email SB?
3- or is there a better way?
TIA
tony
SCar87011738
SOLVED:
the email was not sending because of a problem: the select field has the form tag pointing to another form. Changing it to the actual form solved the problem.
Just to make things clear I've set the email SB trigger to my select field. Then I modified it this way:
if ((((isset($_POST["myselectfield"]))?$_POST["myselectfield"]:"") == "Express")) { //WA Universal Email
$Email = new WA_Email("myemail");...[/snip]
