Datepicker showing today's date on load, despite defaultDate: null?
Thread begun 2/27/2020 7:00 am by Nathon Jones Web Design | Last modified 2/27/2020 9:43 am by Ray Borduin | 1741 views | 3 replies |
On this page, when the datepicker field loads it's showing today's date by default:
https://www.sportsmedicalcertificates.com/health-screening-form.php?tab1=1
Despite this...
$(function(){
$('#datepicker_1').datepicker({
dateFormat: 'dd-mm-yy',
changeMonth : true,
changeYear : true,
showAnim: 'show',
maxDate: "-16y",
yearRange: '1920:maxDate',
defaultDate: null,
onClose: closeDatePicker_datepicker_1
function closeDatePicker_datepicker_1() {
var tElm = $('#datepicker_1');
if (typeof datepicker_1_Spry != null && typeof datepicker_1_Spry != "undefined" && datepicker_Spry.validate) {
datepicker_1_Spry.validate();
tElm.focus();
</script>
Can you help? Thank you.
NJ
What is the html for the field? I'm assuming you want it to start blank?
Yes, it needs to be blank otherwise people just don't bother completing it and it won't fail validation because it already has a date in it.
The HTML is...
<input type="text" class="form-control" name="DOB" id="datepicker_1" placeholder="Date of Birth" maxlength="10" value="<?php echo((ValidatedField("healthscreeningform_984","DOB")?ValidatedField("healthscreeningform_984","DOB"):date("d-m-Y"))); ?>" aria-describedby="basic-addon2" required>
Thank you.
NJ
When you set it to null in the javascript it goes to the default value set in the form element. To make it start blank, you could use:
<input type="text" class="form-control" name="DOB" id="datepicker_1" placeholder="Date of Birth" maxlength="10" value="<?php echo((ValidatedField("healthscreeningform_984","DOB")?ValidatedField("healthscreeningform_984","DOB"):"")); ?>" aria-describedby="basic-addon2" required>
