WebAssist Dreamweaver 20.01 Connection None
Thread began 2/24/2020 6:43 am by Eric | Last modified 2/27/2020 8:22 am by Ray Borduin | 2225 views | 19 replies |
Eric
I have installed webassist. I have removed all php code from a webpage that was throwing out a connection deprecation error. I go into server behaviors. I have 3 check boxes for site, document and testing server. I click the plus symbol and go to recordset. Connection is none so I click define. I have both a classic connection and a mysqli connection defined. When I select either of them and click okay I go back to the recordset page and connection is still none. I am running windows 10 Pro version 1903. I made sure I had the latest dreamweaver build last night. If I can get past the connection issue I should be able to update my website. Your product looks like the old dreamweaver data build. I have tried deleting the connections and rebuilding them. I have closed dreamweaver multiple times. What do I need to do to get this to work?
Please post your phone number and I'll do screen sharing with you to figure out what is going wrong.
Eric
Number privately messaged
Eric
email privately messaged
I just tried calling but could not get through. Please call me using the number listed at the bottom of the webassist.com website.
Eric
private message sent
You just need to use the webassist mysqli recordset dialog for mysqli connections.
Eric
Eric
The webassist Multiple Delete does not bring up a dialog box. The show region has a label error show if on the last page is listed twice. The second entry is show if NOT on the last page. The functionality works fine it is just a label issue.
Eric
