conditional Insert and Update
Thread begun 2/19/2020 12:48 pm by Jose | Last modified 2/19/2020 5:24 pm by Ray Borduin | 2049 views | 5 replies |
Jose
Hi there, I'm wondering why a Conditional Insert or update that work properly in localhost do not work in a live server ?
This work properly till one point. for example, I have 6 input type text but if I add one more it goes empty on update. If it's inserting then it stops working. But it works in localhost.
It could be a difference in the database table. Maybe missing columns or bad credentials on the live version.
Jose
There is no difference in database table and I use Firefox and live version of php the same. It should work but once I submit it nothing go to that field. I will attach the php file and database configuration once I get home.
Jose
Here is an attach.
updatelocale.php is not updating url_rewrite field in database and addlocale.php is not submitting the form.
It might be an issue with the live server settings for:
max_input_vars
or
post_max_size
Since you are using a repeated form it might be hitting limits for those field values.
Use this to check the value on both the localhost and live server:
phpinfo();
It is possible the limit is different and that is why it works on your localhost. Talk to your hosting provider to get help increasing the number of fields allowed in a form post.
Jose
Thank you Ray, I appreciate it
