error logs reports error in query
Thread began 2/19/2020 8:10 am by Sweens | Last modified 2/19/2020 10:49 am by Ray Borduin | 464 views | 4 replies |
Sweens
Hi Ray
I have several queries similar to the following:
$rsSubMenuContent = new WA_MySQLi_RS("rsSubMenuContent",$conn121_i,0);
$rsSubMenuContent->setQuery("SELECT `page_content`.`pg_id`, `page_content`.`pg_url`, `page_content`.`pg_title`, `page_content`.`pg_sortorder`, `page_content`.`pg_browsertitle`, `category`.`pg_url` AS `UnderPage`, `category`.`pg_id` AS `category`, `category`.`pg_title` AS `categoryname`, REPLACE(`page_mainpics`.`mpic_name`,' ','%20')AS mpic_name, `page_mainpics`.`mpic_alttext`, `page_content`.`pg_description` FROM `page_content` Left Join `page_content` AS `category` ON `page_content`.`pg_under_pgid` = `category`.`pg_id` Left Join `page_mainpics` ON `page_content`.`pg_id` = `page_mainpics`.`mpic_pg_id` WHERE `page_content`.`pg_id` <> 1 AND `page_content`.`pg_active` = 'yes' AND (`category`.`pg_url` = ? OR `category`.`pg_url` = ?) ORDER BY `page_content`.`pg_sortorder` ASC ");
$rsSubMenuContent->bindParam("s", "".$_GET['category'] ."", "-1"); //p1
$rsSubMenuContent->bindParam("s", "".$_GET['pg'] ."", "-1"); //p2
$rsSubMenuContent->execute();
The query works fine - but if I look at the error logs on the server, if there is no 'category' listed, I get:
AH01071: Got error 'PHP message: PHP Notice: Undefined index: category in /home/.../public_html/page.php on line 44'
Line 44 is $rsSubMenuContent->bindParam("s", "".$_GET['category'] ."", "-1"); //p1 above.
Is there a way I can do isset (or something) in the query to get round this error.
Many thanks
Chris
The error would happen if someone accessed the page without the url parameter. You can get around it by adding a check to the code like:
$rsSubMenuContent->bindParam("s", "".(isset($_GET['category'])?$_GET['category']:"") ."", "-1");
Sweens
Brilliant! Thanks so much. I can add this on several pages.
The other instance is in an insert behaviour that tracks visits to the page; if there is no referrer, I get a similar error about this line:
$InsertQuery->bindColumn("st_referrer", "s", "".$_SERVER['HTTP_REFERER'] ."", "WA_DEFAULT");
Where would the isset go in this example? (I have tried, but no success)
Very grateful,
Cheers
Chris
It is the same syntax just with the $_SERVER variable instead of the $_GET:
$InsertQuery->bindColumn("st_referrer", "s", "".(isset($_SERVER['HTTP_REFERER'])?$_SERVER['HTTP_REFERER']:"") ."", "WA_DEFAULT");
Sweens
Thanks yet again, Ray.
Cheers
Chris
